Oil Pan Help |
bigcountry48 ![]() Orange Level ![]() ![]() Joined: 28 Aug 2011 Location: Georgia Points: 1100 |
![]() ![]() ![]() ![]() ![]() Posted: 23 May 2012 at 4:50pm |
Ok, I have taken all the bolts out that were holding the oil pan and cleaned it with turpentine, but when I try to pull it off it won't even budge. I've got the two long bolts in the back off, and the lug in the front off, is there somthing I'm suppose to do or what? I need any advice I can get, and this is my 1950 B I'm talking about. I'm trying to replace the oil pan gasket because, it leaks like crazy. Thanks!
1950 B, 1952 pulling wd, and 1954 wd45
R.W ![]() Orange Level ![]() Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
Probably just stuck, pry gently with a large screw driver and it should come off.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
A large wood chisel also works well to loosen up pans and covers. I use the ones that I can hit with my palm and work around the pan or cover. Its amazing how hard the gasket cement sets up (and oil can still leak thru) after 60 +/- years!!
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7496 |
Do not pry it, they are easy to bend. I go around it using a rubber mallet, eventually it will let go from the gasket.
Boogerowen ![]() Orange Level ![]() Joined: 23 Apr 2011 Location: Mannford Ok Points: 431 |
I'm still waiting for that money Daniel, do you have another story to tell me ??????
