Oil filter base to block gasket
Elo76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elo76 Quote  Post ReplyReply Direct Link To This Post Topic: Oil filter base to block gasket
    Posted: 16 Jul 2018 at 10:57am
Have some leakage coming from here and was looking to replace the gasket.  Have been having trouble finding just that gasket without buying a whole kit.
Can RTV gasketmaker/sealant be used here?
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 11:10am
or make your own gasket?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 11:52am
I failed  ESP class thus it helps to know what you are working on?  Wink
Assuming its a WC, WD, 45, B or C or similar  engine oil filter  because they are the ones prone to leaking,, Leave the blue glue in the tube, only takes about 1 minute to make that gasket  from a sheet of rubberized cork using the base as a template. Most of the time you will find that the base is bent where it mates the block.  The fix for that is running it over sandpaper placed on a fat surface
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 6:17pm
Easy way is to run the plate against a 200 grit belt, on a bench top belt sander, or hand file, if you are old school.  What generally happens is the old cork gasket gets leaky, then the bolts get over torqued, when somebody tries to tighten, to stop the leak.  As Butch says, cut a gasket, easy peasy...Wink
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 6:53pm
    Howdy Elo76,
    I don't use cork, seems to leak. I use a plastic top from a gallon ice cream top. Cut the gasket out of that and I had best of luck!
   Kurzy
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 7:56pm
When I redid the motor on my WC, I took the filter assembly off and you could see someone made the gasket out of an old old old Corn Flakes box, you could tell because it was the part of the rooster.  Lord only knows how long that cardboard gasket held.   I made the replacement out of the grey, 1/8" gasket material.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2018 at 7:06am
Agco #70233228 Gasket 2.94 Stiener # acs2397 3.65
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 7:01am
Make sure the base is FLAT and make a gasket out of THICK cork material.
"Burgie"
Rog NCWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog NCWI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2018 at 8:37am
I used JB Weld and filled in the cavity and then filed every thing straight. Purchased some gasket material form a auto parts store and bolted it up to he block. Has not leak since.
Edited by Rog NCWI - 18 Jul 2018 at 8:38am
squirt239 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote squirt239 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2018 at 8:43am
I have an extra one I'll send you.  Private message me your address, or you can email me at info@havlinsfirearmsfinishing.com.  I'll send it out in the mail.
This page was generated in 0.234 seconds.
