Off color Massey 540
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Topic: Off color Massey 540
    Posted: 29 Nov 2017 at 7:36am
So I bought this small combine to replace my G since it has better steps and a hydraulic swinging auger. Lower back issues kinda forced to me! Finally was able to get my little weedy patch of beans combined yesterday backed it. In the shed to unload and the dang unloading auger doesn't work. Any of you guys run a Massey? And run into this issue? Where to start looking, as the bearings and belt all look good! Thanks for any help. Kurt
WD D17D 170 190xt 190xtIII 200 7020
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 5:18am
So I put a pipe wrench on the drive shaft of the unloading auger and could turn it both directions with a little effort. But start the combine and nothing. The auger still doesn't turn.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 6:26am
F2 or M with hydraulic swing auger would been a much better choice.    MACK
allisrutledge View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 6:43am
I don't know anything but can ask questions . is it mechanical or Hyd or electric drive ? I have a neighbor with one I will get his number and pm you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 7:15am
had a mouse chew my unload auger swing wire once
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 8:51pm
Yes it would have been! I couldn't find one under 7500 for a F2 and didn't even look at M or L's as I don't need one that big. As I'd like to still have most equipment shedded.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2017 at 8:56pm
It is mechanical drive engaged by a lever in the cab which engages a belt that drives a bunch of roller chains and bevel gears. All the bearings seem good along with the chains. The upper bevel gears also look good and not binding however I can't get to the lower ones as the bin is full! But it doesn't seem like they are over riding either. So I just don't know. As I said I can turn the whole works with a pipe wrench!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 11:08am
I can only guess , but I would look for a key out of a pulley or a pin missing somewhere. Get someone to slowly engage it and look where the shafts are not turning. Please be careful and keep all your fingers!!! No loose clothing and all that safety stuff.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2017 at 7:22pm
When you engage the unloader, what does turn and what doesn't?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 7:41am
After all day yesterday pulling all shields and shoving a old shirt in the auger to stop the flow I took the lower shield to see the lower bevel gears look good too along with the bearings. Then I had to get pig and calf feed so I went to the mill. Got talking to a guy and he said it sound like your belt. So after getting home and the oldest boy got home we pryed up on the belt and it started to turn. Almost broke my arm doing so but atleast now I got a belt ordered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2017 at 9:24pm
Glad you figured it out and still got all your fingers.
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 2:53am
There is a reason those old Massey's are way cheaper than a Gleaner.  My great uncle traded a worn out 1969 square back 55 John Deere on one back when they first came out in '78 and he had all kinds of problems with that thing from day one. The engineers from Brantford even flew down to work on it a couple of times.  When it wasn't in the shop that 540 could never keep up with dad's flat screen Deere 4400 diesel in beans.
The four cylinder Perkins in that 540 was very reliable though, and it used significantly less fuel than the Deere 4400 did to cover the same number of acres.
Whenever you park that 540 for the season pin the clutch pedal down.  From under the cab pull the pedal down and stick a bolt through the hole that is drilled right below the pedal.  If you don't, it will stick and you will have to take the clutch assembly off and disassemble it to get it unstuck.
Edited by VAfarmboy - 03 Dec 2017 at 3:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 3:54pm
Got the new belt on and it worked! Woohoo. Back in business! And with all that the old belt looks good but it sure is stretched.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2017 at 3:58pm
[QUOTE=MACK] F2 or M with hydraulic swing auger would been a much better choice.    MACK
Whenever you park that 540 for the season pin the clutch pedal down.  From under the cab pull the pedal down and stick a bolt through the hole that is drilled right below the pedal.  If you don't, it will stick and you will have to take the clutch assembly off and disassemble it to get it unstuck.  <span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 14px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: -webkit-left; text-indent: 0px; text-trans: none; white-space: normal; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; : rgb255, 255, 255; text-decoration-style: initial; text-decoration-color: initial; display: inline !imant; : none;"><span>
</span></span><span style="color: rgb51, 51, 51; font-family: Verdana, Arial, Helvetica, sans-serif; font-size: 14px; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; orphans: 2; text-align: -webkit-left; text-indent: 0px; text-trans: none; white-space: normal; widows: 2; word-spacing: 0px; -webkit-text-stroke-width: 0px; : rgb255, 255, 255; text-decoration-style: initial; text-decoration-color: initial; display: inline !imant; : none;"><span></span></span>
That's ok I knew going in why they were cheaper I just needed a machine with hydraulic swing auger! On the plus side it sure does have better steps than gleaner for me to get up there at this point. Thanks for the heads up about the clutch!
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 11:53am
540's were a over sized version of 300. We sold a bunch of them because of the price for small farms. And were very good machine in their day!
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2017 at 8:08pm
That is interesting information about the clutch on the Massey combine.  That's a problem I have with my 750 this fall, although I've had it around 10 years and never had it stick before.
Allis Express participant
