Off Color (ish) - Aftermarket Hydraulic Pumps
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Topic: Off Color (ish) - Aftermarket Hydraulic Pumps
    Posted: 26 May 2017 at 8:30am
Off color in the sense I'm working on my Ford 6610.  But what is the consensus of the "economy" no-name aftermarket hydraulic pumps on the market today?  I am looking at a new pump for my 6610 because it stripped the shaft and splined hub inside the main body gear where it goes to drive the low pressure section of the pump for the PTO and Dual Power circuit.  The parts to fix it are $350-$400 range, and the aftermarket replacements can be had for as low as $230.  I know they are likely throw-away pumps in that they won't use the OEM seals and gears, but for the diffrence (a reman from NH or a new Dynamatic OEM pump are $6-800), if the reliability is decent on these pumps, I feel it might be worth the risk, especially when money is tight on the repair budget.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 9:41am
A good source of pumps is Baum Hydraulics. http://www.baumhydraulics.com
Their on line downloadable catalog searches better than their website but shows resale prices, they give a discount for direct purchases, typically coded as DATE 2000 on each page, sometimes different values down the page, 2000 means 20% discount.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 11:53am
Thank you for the link!  I'll look into it.
Hurst
5800 Hours
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 11:59am
I picked up a brand X 2 stage one on the net for $125, we used it on a log splitter we were building.  Running it with a big honda engine.  works great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2017 at 6:43pm
Here's another good source:
