Odd Hybrid JD-Farmall tractor - in PA auction
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: Odd Hybrid JD-Farmall tractor - in PA auction
    Posted: Yesterday at 5:43am
Saw this oddity while looking at auctions. Guy connected a JD and Farmall tractors.
I would be concerned about welds at final drive as I thought the metal was iron, not cast steel and steering being consistent/tracking together.
Edited by KMAG - Yesterday at 5:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:20am
What a STOOPID project !!!
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:28am
A classic case of someone that has too much time on their hands!!! My question to things like this is; If you have the ability to build something like this, and it actually works, why not do something constructive?! John Kinzenbaw never built a pos like that.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 9 minutes ago at 8:03am
They had an argument wiht the hired hands, one wouldn't drive a farmall, the other wouldn't drive a deere. Now when it's work time they pick which one they want to drive.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 7 minutes ago at 8:05am
Hey guys remember the time during the big snow storm we were all down at the shop smoking weed?
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 4 minutes ago at 8:08am
Are there 2 sets of cracks near the Farmall final drive flange or are they casting lines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 51 minutes ago at 8:21am
something I'd expected to see on the Red Green Show, decades ago.....
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 25 minutes ago at 8:47am
he thought if he put them together he might get as much work done as 1 WD45
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 27 minutes ago at 9:45am
It would need a whole lot of duct tape to qualify....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 6 minutes ago at 10:06am
One thing for sure with two WD-45's is, if you put them both in the same GEAR, they would go the same speed if engines were synch'd RPM wise. That Red/Green combo is engineeringly dumb.
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 47 minutes ago at 11:25am
Now Doc how do you know he don't have the PCM all tricked up on that contraption ??? Dave
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 40 minutes ago at 11:32am
If I remember right there was an article on this tractor in one of the farm magazines thirty-some years ago. I think the speed issue was one of the big things to overcome.
And since no one else has made the comment - what else would you do with a JD and a Farmall?
Ted
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 2 minutes ago at 12:10pm
I think this falls into the category... just because you can... doesn't mean you should!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 1 minutes ago at 4:11pm
If the JD's (or the IH's)diff is welded, then the speed thing isn't much of a problem...Wink
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 8 minutes ago at 5:04pm
Did some searching and found the article. Farm Show magazine, Vol. 30, no. 4. Reading it he didn't figure out how to overcome the speed issue, he could run it from one tractor or the other. So probably locked differentials in both. This also wasn't the first time he put two tractors together, just the first time they were different tractors.
https://share.google/2nOFfC88y7v2iVCbm
Ted
Edited by TedN - 14 hours 5 minutes ago at 5:07pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 17 minutes ago at 6:55pm
if the wemon dont find you handsome at least they will find handy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 54 minutes ago at 8:18pm
https://www.auctionzip.com/Full-Image/4115909/fp68.cgi
link will have an extra %20 at the end of heading.. delete that , then hit enter..
Edited by steve(ill) - 10 hours 53 minutes ago at 8:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 55 minutes ago at 9:17pm
What a waste of time and money IMO.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 57 minutes ago at 5:15am
look at the bright side, they didn’t waste a old Allis doing that!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
