Odd Hybrid JD-Farmall tractor - in PA auction |
KMAG
Joined: 26 May 2020 Location: Elizabethtown, Points: 688 |
Topic: Odd Hybrid JD-Farmall tractor - in PA auctionPosted: 15 hours 17 minutes ago at 5:43am |
Saw this oddity while looking at auctions. Guy connected a JD and Farmall tractors.
I would be concerned about welds at final drive as I thought the metal was iron, not cast steel and steering being consistent/tracking together. ![]() ![]() ![]() Edited by KMAG - 15 hours 14 minutes ago at 5:46am |
Posted: 14 hours 40 minutes ago at 6:20am |
What a STOOPID project !!!
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4260 |
Posted: 14 hours 32 minutes ago at 6:28am |
A classic case of someone that has too much time on their hands!!! My question to things like this is; If you have the ability to build something like this, and it actually works, why not do something constructive?! John Kinzenbaw never built a pos like that.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3120 |
Posted: 12 hours 57 minutes ago at 8:03am |
They had an argument wiht the hired hands, one wouldn't drive a farmall, the other wouldn't drive a deere. Now when it's work time they pick which one they want to drive.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3187 |
Posted: 12 hours 55 minutes ago at 8:05am |
Hey guys remember the time during the big snow storm we were all down at the shop smoking weed?
KMAG
Posted: 12 hours 52 minutes ago at 8:08am |
Are there 2 sets of cracks near the Farmall final drive flange or are they casting lines?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25118 |
Posted: 12 hours 39 minutes ago at 8:21am |
something I'd expected to see on the Red Green Show, decades ago.....
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 810 |
Posted: 12 hours 13 minutes ago at 8:47am |
he thought if he put them together he might get as much work done as 1 WD45
KMAG
Posted: 11 hours 15 minutes ago at 9:45am |
It would need a whole lot of duct tape to qualify.... |
Posted: 10 hours 54 minutes ago at 10:06am |
One thing for sure with two WD-45's is, if you put them both in the same GEAR, they would go the same speed if engines were synch'd RPM wise. That Red/Green combo is engineeringly dumb.
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 261 |
Posted: 9 hours 35 minutes ago at 11:25am |
Now Doc how do you know he don't have the PCM all tricked up on that contraption ??? Dave
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 155 |
Posted: 9 hours 28 minutes ago at 11:32am |
If I remember right there was an article on this tractor in one of the farm magazines thirty-some years ago. I think the speed issue was one of the big things to overcome.
And since no one else has made the comment - what else would you do with a JD and a Farmall? Ted |
ToddnwIl
Posted: 8 hours 50 minutes ago at 12:10pm |
I think this falls into the category... just because you can... doesn't mean you should!
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55112 |
Posted: 4 hours 49 minutes ago at 4:11pm |
If the JD's (or the IH's)diff is welded, then the speed thing isn't much of a problem...
TedN
Posted: 3 hours 56 minutes ago at 5:04pm |
Did some searching and found the article. Farm Show magazine, Vol. 30, no. 4. Reading it he didn't figure out how to overcome the speed issue, he could run it from one tractor or the other. So probably locked differentials in both. This also wasn't the first time he put two tractors together, just the first time they were different tractors.
https://share.google/2nOFfC88y7v2iVCbm Ted Edited by TedN - 3 hours 53 minutes ago at 5:07pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4060 |
Posted: 2 hours 5 minutes ago at 6:55pm |
if the wemon dont find you handsome at least they will find handy
Joined: 11 Sep 2009 Location: illinois Points: 90327 |
Posted: 42 minutes ago at 8:18pm |
https://www.auctionzip.com/Full-Image/4115909/fp68.cgi
Edited by steve(ill) - 41 minutes ago at 8:19pm |
