OC Massey Fergusen
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Topic: OC Massey Fergusen
    Posted: 13 Aug 2011 at 4:25pm
I noticed today the clutch on our Massey Fergusen 135 has no play at the end of the pedal. I don't see a way to adjust it. Does anyone know how to? Thanks, Scott
Jim seIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim seIl Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2011 at 9:52pm
Scott the shaft in the bell housing that the thowout bearing is on has a hole in it and the arm on the shaft has a bolt through it to clamp it to the shaft put a large punch in hole in shaft and loosen clamp bolt hold slight pressure on throw out then move arm so as to have 1/8 inch clearance between bellhousing and stop on arm hth Jim
