OC JD 7000 Planter Question |
ibleedorange
Joined: 08 Feb 2010 Location: Harvard, IL Points: 173 |
Topic: OC JD 7000 Planter QuestionPosted: 30 May 2017 at 4:39pm |
My neighbor has a JD 7000 4 row planter. She plants about 80
acres of sweet corn every year. Her lead man told her that about half the seed
is getting crushed or cracked. Anybody any experience like this? I put in new augers from Shoup a couple years ago.
Thanks ahead
of time for any insight you could provide.
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1561 |
Posted: 30 May 2017 at 5:14pm |
New augers for what? That planter should not be crushing the seed. I'm not totally familiar with the junk Deere but I don't think you have to change any settings when you switch seed size.
bakwoodsfarm
Joined: 02 Sep 2010 Location: Woodleaf,NC Points: 511 |
Posted: 30 May 2017 at 5:27pm |
The only augers are in the fertilizer bins, it has a belt metering system, I don't see how it can crush seed at all.
Daehler
Joined: 23 Nov 2010 Location: Lexington MO Points: 1167 |
Posted: 30 May 2017 at 5:50pm |
If the meters havent been tested, they need to be. Something could be broke or out of time. We have our finger meters ran every year to make sure singulation is up to par and to make sure there are no broken parts. It is posible that when the finger comes around and grabs a kernel it could crack it especially if there is to much tension on the spring, Sweet corn seed is a little different than field corn. By the way 80 acres is a lot of sweet corn!!
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2879 |
Posted: 30 May 2017 at 8:44pm |
Put it on the test stand. But I doubt it's the meters. We planted a chunk without issues. We could even plant sunflowers without issues.
Wayne180d
Joined: 08 Dec 2015 Location: Gilman, Il Points: 5946 |
Posted: 30 May 2017 at 8:49pm |
I planted with a 7000 for five years and never had an issue with crushing or cracking the seed. I wanted a IH Cyclo but this one came available and was priced right for a Deere in our area and was very happy with it.
shameless dude
Posted: 31 May 2017 at 2:36am |
some 7000's were finger fed, and some used the old style planter plates, which is that one?
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12326 |
Posted: 31 May 2017 at 6:21am |
Exactly what Shameless said, finger pickup or plate style meter? I'd think if plates and your plates are too big, you could be crushing some seed. I don't know about "half", that would be terrible, but it could happen I suppose if the cell size was way off.
"Belt metering system"? I have no idea what this means. Nothing like that on a 7000.
old farmer
Silver Level Access
Joined: 12 Oct 2011 Location: Sturgis, Mich Points: 341 |
Posted: 31 May 2017 at 6:58am |
Deere uses a belt to get seed from finger pickup to discharge point at ground level.
Tbone95
Posted: 31 May 2017 at 7:05am |
Yeah, but that's hardly the metering system.
