no high |
mintenfarmer ![]() Silver Level ![]() Joined: 22 May 2015 Location: Minnesota Points: 191 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jul 2015 at 10:47pm |
7050 had it for 14 years hi-lo went out slowly lever moves back and forth freely like a connector wire shaped is it easy to fix works without it in low
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
May need some more info. What you posted sounds confussing.
Are you referring to the buttons on the floor, that is the only thing I think that could go out "Slowly" Or are you referring to the high low "lever" on the side console? I can't imagine that going slowly, as it is a mechanical gear shift?? These are known for broken cable ends, and tight cables. A couple hundred in cables and end parts will typically get you back in business. If on the other hand you are referring to the buttons on the floor, that is a hydraulic two speed power shift clutch, and it can certainly cost some dollars, especially if by "slowly" you mean it was operated for a long time slipping,until it stopped working all together. |
Still in use:
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2388 |
The 7050 high, low, park cable is clamped at the rear of the tractor with a rather flimsy U shaped clamp. It uses two allen head capscrews to secure it. They have a habit of getting loose and that allows the outer shell of the cable to slip. The cable has a notch in it so that you get it located properly. The later tractors used a U bolt that was a much improved version.
