new to me plow
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: new to me plow
    Posted: 3 hours 57 minutes ago at 1:01pm
i got this with a couple WD's I bought at an auction here in NM. I studied the plow ID on the knowledge base, looks to me to be a WD-#53 pick-up plow,, best measurements I get it's a 14",,  so I found an owners book on ebay,, looks like there is a lot of the adjustments are WAY off, first, the lift links are above the lift bar, next the pull bar and beaming adjustment are set too far to the RH side.  I gots the adjustments soaking,,
What ya'll think??
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Posted: 38 minutes ago at 4:20pm
that is the hot set up .
Dave the plowman specializes in snap coupling plows .
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 minutes ago at 4:28pm
Someone may have had that plow hitched to a D17 which would need longer lift links to not have the hitch hitting the bottom of the transmission case when fully lifted.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 minutes ago at 4:44pm
That's nice. It was coverboards and moldboard extensions
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 minutes ago at 4:48pm
The lift links need to be flipped over a half a turn on the hinge area. The bottom needs to be inside the U part. Andy
