New off color tractor |
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4802 |
Topic: New off color tractorPosted: 05 May 2017 at 9:43pm |
Put on 900 miles today to get my new tractor. It's a Ford Model T with a tractor conversion kit on it. I'll stick my spare engine in it and it should be ready to go. You basically remove the rear wheels and install the tag axle and braces and boom, poor mans tractor. This one has been shortened about 3 feet.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4903 |
Posted: 05 May 2017 at 9:48pm |
I like that!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 05 May 2017 at 10:23pm |
Awesome!! Ford "tractor" bug strikes again! Lol
Edited by CrestonM - 05 May 2017 at 10:23pm |
chuck (WI)
Joined: 07 Feb 2010 Location: wisconsin Points: 200 |
Posted: 05 May 2017 at 10:29pm |
Never knew they did such a thing, maybe that's what brought em to the TW series.
Ron(AB)
Posted: 06 May 2017 at 12:18am |
Wow! Are times getting that tough!
I thought Trump was making things better? (joking) It looks great! Does/did it run on alcohol or gasoline? |
shameless dude
Posted: 06 May 2017 at 12:41am |
I've seen pics and read stories on them things! but was never really able to find out how much they could pull, like plows and disks? maybe they just used them to seeding and harrowing? had to be light duty stuff since it is a ford! (poke,poke)
CrestonM
Posted: 06 May 2017 at 12:55am |
Ouch! Lol |
JayIN
Posted: 06 May 2017 at 4:29am |
Seen them before at shows. Very, very cool. Would love th have one!
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 06 May 2017 at 5:14am |
Cool Man!!!
B26240
Posted: 06 May 2017 at 6:03am |
Bugs in general are real popular at the rolog show and I see then at other shows also. I bet they worked real good for haying thinking more the ones with rubber tires and twin transmissions.
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5910 |
Posted: 06 May 2017 at 6:05am |
Link to a picture of a conversion: Gary http://www.mtfca.com/discus/messages/257047/278922.html?1340397506 |
MNLonnie
Posted: 06 May 2017 at 6:47am |
I'm not sure what they were capable of but about all there was is horse drawn equipment at the time so I guess anything a horse can do? It should go good with the Doodlebug that I built. My bug has a Model A tranny behind the T tranny so there are lots of gears to choose from.
CrestonM
Posted: 06 May 2017 at 7:54am |
So Lonnie.....how fast will that one with 2 trannys go??? Lol
shameless dude
Posted: 06 May 2017 at 9:45am |
isn't that what that golfer used all the time?
MNLonnie
Posted: 06 May 2017 at 10:43am |
The 2 trannys won't get you going any faster but you have a pile of granny gears to pick from.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11173 |
Have seen a few around Ohio at shows
Gerald J.
Posted: 06 May 2017 at 12:13pm |
I have a book on model Ts. There were several variations on converting Ts to tractors. Some fairly simple, some harder like changing the axle. There was also a factor option for the TT trucks (that had a worm drive rear axle with a higher ratio so more torque to the wheels than the car axle but using the same engine and transmission up front) to add a three speed lever shift transmission right behind the standard T transmission. I have found a least half a dozen different transmissions used. The top speed of the truck was about 25 mph with the worm drive rear axle. The three speed plus reverse option gave the truck lots of slow speeds and one confusing forward gear with both transmissions in reverse.
Gerald J. |
MNLonnie
Posted: 06 May 2017 at 4:19pm |
My TT truck has the high speed (5.16:1) rearend it and my Doodlebug has the low speed (7.25:1) in it. Like you said the high speed tops out at around 25 mph and the low speed about 18 mph. My TT had a Jumbo 3 speed Transmission behind the stock one which would give you underdrive, straight through and overdrive so it would go few miles an hour faster but I removed it since I don't haul anything I didn't need the underdrive and those trannys are very noisy with straight cut gears.
