New Idea 30a Sickle Mower on my CA
SGTJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SGTJ Quote  Post ReplyReply Direct Link To This Post Topic: New Idea 30a Sickle Mower on my CA
    Posted: 19 Jun 2019 at 9:48am
So its not necessarily an AC question -- but I'm using my new (to me) sickle mower on my CA and the bar lifts on its own during operation.  I'm trying to cut about 5 acres of hay and about 60% of the time the bar stays low and cuts clean.  But that 40% of the time the end of the bar closest to the machine tends to lift up on its own.  I can use the hand clutch to stop and it'll lower back down - but stopping and starting every 4ft is getting frustrating.
 I have an owners manual coming in the mail, and I think it might have something to do with the slope of the field I'm cutting -- though its a relatively flat field.
WD , CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 10:26am
You probably have the setting on your hydraulic pump wrong for what you are doing. It should be set for “ lift and hold”,
SGTJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SGTJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 11:42am
its a tow behind mower -- I'm not using my hydraulics
WD , CA
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 11:46am
Did some of them have a mechanical lift on the bar? Sounds like a mower issue, not a tractor one if you aren't using the hyd.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 2:21pm
Is the lift rope to short? Had that problem years back.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 8:27pm
That was my issue, a too short rope.  Fixed that and all was fine after that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2019 at 10:38pm
Does that mower have a wooden pitman stick
SGTJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SGTJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 9:57am
Plenty of slack in the rope
yes it has a wooden pitman arm
I think that the end of the bar farthest from the tractor is maybe getting clogged / hung up on the ground ?  Maybe that pressure is forcing the bar upwards ... no idea hopefully my manual arrives today
WD , CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 3:45pm
I just had some flash backs to mowing with a sickle bar mowers.
When I was about 8 I got to ride the old McCormick 5 foot sickle bar mower. It had been converted from horse drawn to a tractor pull unit. Grandpa and I mowed 60 acres each year for 10 years while it was in the soil bank. (they paid you to not grow crops. I was barely big enough to raise the bar of the mower with a lever and standing on the foot pedal!
Then later on Dads farm there was the New Idea sickle bar (7 foot) that worked pretty well except for down clover. Then we had to only mow in one direction.
And just today I helped friend Gary and Rick put new sections in a 9 foot bar for a New Holland Haybine.
Times have changes but the sickle bar is still here.
Maybe have someone walk behind and watch what is going on as you mow? If there is a trip mechanism to raise the bar it may have issues?
Pictures might help too?
Edited by Sugarmaker - 20 Jun 2019 at 8:30pm
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2019 at 5:52pm
Does it have a spring that assists the lift- maybe too tight?
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2019 at 5:16pm
You probably need new sickle sections, ledger plates and properly adjusted hold down clips. Or you are driving way to fast or the points of the guards are pointed down instead of flat or slightly up.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2019 at 9:36pm
There was a special end sickle section listed as an after market attachment.  This section had two cutter blades on it to be used in the very end of the sickle bar where it went through the end guard.  It was made for sickle bar mowers that clogged on the end.  I never sold one but remember seeing them in some literature.
Good Luck!
Bill Long
yzfarmgirl28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yzfarmgirl28 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 8:53am
Sounds like you may have a broken or weak spring on the lift mechanism. Remove top cover and take a look .
SGTJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SGTJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 10:10am
Well it looks like a I have another project for this weekend ... Sleepy
WD , CA
JaredC(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JaredC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2019 at 8:18pm
Let us know what you find....and let's see some pics of the hay making with your equipment :) Neat stuff!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2019 at 6:45am
We came across some new idea pitman sticks, would you happen to know part number
