Needed, 2500 exhaust manifold
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Topic: Needed, 2500 exhaust manifold
    Posted: 26 Nov 2011 at 7:18pm
I'm in need of a exhaust manifold for a 2500 gas for my 190.
I think the 2800 engine will be the same manifold. I will take the
intake manifold as well if they will not seperate.
 thanks for the input.
More than I need
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 7:40pm
There was a complete assembly on eBay within the past week. Don't know if it is still there or not.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 7:44pm
  2 different manifolds used--onecarb is mounted in center ---other is offset??????
   my 2 cents
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 8:09pm
Thanks Norm, I checked mine and it is a center mounted carb.
Brrr, wind is cold in the Dakotas tonight.
More than I need
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 8:47pm
The listing is still on eBay. Do a search for allis 190, and it will come up. We have a 190/2500 and a 190XT/2800. Both use the same manifolds.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 10:44am
  it is possible  both of my 190 had the center mount carbs   offset are available aftermarket      my 2 cents
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 8:19pm
bump
More than I need
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 9:08pm
I have one some one made out of steel sq tube if you would be interested.  MACK
49WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49WF Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2011 at 2:35pm
Thanks Mack, that was going to be my end of the road option.
More than I need
