Need an Injection Pump for D21
T16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T16 Quote  Post ReplyReply Direct Link To This Post Topic: Need an Injection Pump for D21
    Posted: 17 Jan 2012 at 12:48pm
We're fixing up a D21 series 2 and discovered the injection pump had water in it and it'll take a couple thousand to fix it. Surely someone has a good used pump we could buy?? Or maybe someone can recommend a rebuilder that would have a reasonable priced unit that's available? Thanks in advance for the help!
swensonrv@srt.com
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 1:36pm
Have one off a 220 that ran.....
Slade(TN)
615-542-6999
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 3:38pm
That oughta work
T16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T16 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 4:35pm
220 and 210 had a cable operated shut off. Would the parts for the electric shut off work on a 220 or 210 pump?
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 5:33pm
Yes it will work. You can transplant the top onto your new pump with timing advance.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 8:57pm
I have a 220 pump on a D-21 and installed the electric shut off.  T16 ? Does your handle tell us that you have a 'Sugar Babe' at home in the shed?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2012 at 9:26pm
I could rebuild yours. I have enough parts to fix whatever is wrong, and keep it correct. slade, pm me for $ of yours if it's still available, and T 16 doesn't buy it. thanks, Ed.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 12:23pm
Bryant Combine has/had my old 210 engine, ran excellent(bad block).  800-255-1071
This page was generated in 0.058 seconds.
