Need a runable wd-45 or wd engine
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Topic: Need a runable wd-45 or wd engine
    Posted: 18 Jan 2010 at 1:19pm
I need a runable wd-45 or wd engine. Doing a tractor for a friend, he took block and head and had crank turned to a good ole boy friend of his. to make a long story short, good ole boy wants 2000.oo dollars and engine will be ready to go! Friend who owns tractor cant afford it, so looks like he needs a runable engine. Can any one help? Don in Indiana thanks!!
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 1:41pm
This member was talking about sell a wd45, email him DAVID leonard(almaleonard@msn.com) Edit this address
Danny Raddatz
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 1:54pm
This one says it runs, but uses oil!  Wide front, with extra rear tire and tube $850.00.  Not mine!http://lincoln.craigslist.org/grd/1517579397.html
Greg Kroeker
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 4:22pm
I have a WD45 that I am going to pull the motor and install a 230 6 cylinder engine in it.  It turned over by hand the other day so I believe it would not take much to get it running.   I would take $600 for it as is.
Located in Oblong, Illinois
Phone # is 618-943-0161
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 4:44pm
Adam I gave you a call got your answer machine, left my number. Did you have the 45 running? Don in Indiana Thanks
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 5:43pm
Don, I sent you an e-mail, have a WD in south central Indiana
Andrew Kimbrough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Kimbrough Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 5:57pm
Don,
I dont know where you are from, but I saw this WD on craigslist in Redkey, IN.  Says it runs good and they only want $850 for it.
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2010 at 5:58pm
get a combine moter out of like a e gleaner
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2010 at 7:52am
Adam
Won't you need a WD45D steering post to do this?
This page was generated in 0.154 seconds.
