Need a few parts for A tractor project
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Topic: Need a few parts for A tractor project
    Posted: 26 Apr 2017 at 3:46pm
Okay, Picked up an A Allis from an auto 'parts yard'... Needs a few items...
 Okay, so I need lots of items for this bad old abused, neglected boy... Yes, this is all I got. No heads or radiator or tin  or fuel tank, nor the engine side covers.
 and worse...
  The front cover of the engine that is part of the front axel support is broke.  A previous owner had made a bracket for the front support and bolted it to the webbing which then broke the front cover itself out.
  By chance, does anyone have that bolster /engine cover laying around?
  Sure will be a project, and Lots and LOTS of attention....  Thanks for looking, JC
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 3:51pm
wow, that is a project.  good luck, dt
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 3:52pm
nice find!!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 4:11pm
One good thing about fixing that tractor is when done they are worth good money. Only a few collectors have them.   Good luck on a big project!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 4:58pm
Wow good luck.
So on older engines what was the reason to acces the side of engine.
Dek Thorne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dek Thorne Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 5:25pm
Nice find
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 5:46pm
Great find! What's the S/N?
I can't find your other thread...did you find out anything about that bracket over the PTO cover?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 6:11pm
JC, kinda reminds me of the last line, in this classic:
 [TUBE]http://youtu.be/WL3V8I49gHA[/TUBE]
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 6:15pm
Should have a lot of the engine parts here in Cambridge if you need some
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 6:58pm
Mike Z, those access holes were to make adjusting the connecting rods easy and to take the pistons out the bottom end without taking the heads off.
Creston, serial # A26094.  The other thread is at bottom of page 3 already, and no, I did not find out, but think it was maybe for part of seat support? Just guessing
DD, like one fellow said, 50 dollar tractor, 250 dollar magneto... LOL
 Gary, I will have to remember you when I start getting into that engine...
Does anyone know if the front cover is the same on the A as on the model E ?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 7:08pm
'E' front cover is quite different.  That one is unique to the 'A'.  If all the pieces are there, it could be welded if you can get it to a good cast iron repair shop.  There is a very good one here but it wouldn't be cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 7:24pm
Thank you for putting an end to that question.
   Now the question is if the front cover isn't going to be cheap, How much of the tractor comes with it?  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 8:52pm
Lol! "Hey Bub, you need a house to go with this door knob!"
Those were the kind of tactics I used to try! "Hey Dad, I've got this old operator's manual, now I need the combine to go with it!" Lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2017 at 1:14am
I have a front cover, water pump, heads valve train parts & more for it. I would like the front cover to find a new home. Give me a call at 612-508-4759. Thanks Matt
Owner of Matt Scott LLC
http://www.mattscottllc.com/
This page was generated in 0.058 seconds.
