my toys
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Topic: my toys
    Posted: 17 Feb 2012 at 6:18pm
hers my girls
Edited by allismanamp - 17 Feb 2012 at 7:32pm
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 6:21pm
....the suspense is killing me.Cool
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 6:23pm
yepConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:23pm
sorry first time trying to do this and like everything else i learn it is alot of trail and error
Big smile
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:34pm
is there only i pic per post? i tried posting my pulling wc with my ca but the wc covered up the ca?Smile
~AMP~
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:34pm
Are your front rims 17" or have they been cut down?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:39pm
me and my dad actually put this tractor togather out of spare parts he had on the parts wagon so i dont really know about the rims im assuming there stock spoke rims for a wc though the rear rims were cut and made wider for the fatter 8 ply firestone tires i put on her that helped first time pulling i slipped the clutch with the new tires so i split the tractor and put a wd 45 diesel pressure plate a button clutch and springs of a 190 and now i can pull in third gear on a dirt track and she still spins the tires
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 7:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 8:00pm
When I used the forum upload and wanted more than one pic, I would type a letter hit enter a couple times and type another letter etc, etc. Go back to the first letter and type your text, then add picture below in the open space.
 I have found it easier to use photobucket and then your pictures will always show up. If you keep using the forum upload, you will run out of space and have to delete some pics to upload more. Then the original pics that you uploaded and had to delete will not show up in the old post. If you use photobucket the picture will always be there.
 If you upload to a free photobucket accout all you have to do is go to the picture you want and copy the [img] file, past it in with your text and you are  done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 8:05pm
ya i i had to make new brackets to fit my belly mower under neath also the lift bracket i made all i got was the belly mower then found a pipe for underneath that was off a far mall c or something so the belt idler pulley plates were all wrong then the belt was shot and the wheels were all twisted up but i straighten and cut and welded and ground and now i have i nice mower tractor for around the farm but i got 200 bucks in it and about 10 hours of fab time so i think i did all right got lucky and found a new belt on ebay for 48 bucks its not a woods but it works i never knew it ether but if you lower your belly mower down on a block of wood it saves your belt drastically its kinda a no brainier but when your in a hurry you skip the simple things some time i also heard if you park your tires on wood they don't crack as easy too but i move all my stuff quite often so they don't dry rot any way LOL
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 8:43pm
i made a album through photo bucket  but i cant follow how i copy the image then were i paste the image to for it to show up on the post i create little help?Shocked
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:57pm
Go to your picture in photobucket, I keep 2 windows open so I can go back and forth from photobucket to my new post. Click on the picture you want and look for a box that says LINKS. The bottom link says IMG code, copy that line ( it begins with [IMG] ). Now go to your new post and paste that IMG code in with your text.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 10:01pm
This page was generated in 0.053 seconds.
