moisture around Carb. |
Author | ||
somebody ![]() Silver Level ![]() ![]() Joined: 03 Jun 2010 Location: western NC Points: 111 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Jun 2011 at 1:36pm |
I have a D17 226 gas engine, There is moisture builds up around where the carb bolts to manifold, I noticed last winter there was frost forming there but didn't think much about it. I ran it about 2 hrs. and the moisture was still there.
Anybody got any ideas?
Thanks and wish everyone a great weekend.
Sponsored Links | ||
Stan R ![]() Orange Level Access ![]() Joined: 03 Dec 2009 Location: MA Points: 969 |
My guess is that it is standard heat of evaporation. i.e. when a liquid goes to vapor, it absorbs heat, hence cooling the metal. Not to worry.
http://en.wikipedia.org/wiki/Enthalpy_of_vaporization |
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
condensation caused from temperature difference between the inside of the throat and the outside. Moisture in the air collects in that area. If you wear glasses and have the air conditioner turned real cold in your car then get out of your car into hot humid air you get them fogged up. That is the same thing.
I used three tractors yesterday and had the same thing on all three. Actually I used four but the one was diesel and I didn't look at it. I lift the sides on the Oliver 77 to turn the gas of as soon as I shut it off and it has more moisture that the Allis B or the Farmall C that I used.
Yep, it's humid out there. My CA and Oliver 60 do it too. |
Mystery solved, Thanks guys, The main reason I was asking is ever now and then the engine would shut off but would crank right back up or if it started to die and I caught it in time to quickly pull choke and right back off it would keep running so I was wondering if I had water or carb. trouble.
I really appreciate you guys you help a lot of people.
R.W ![]() Orange Level ![]() Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
My Farmall smta dose it all the time nothing to worry about.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21359 |
All the ones that run really good do that.
j.w.freck ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
in aviation this is known as carb.icing or induction icing.this really gets the pucker factor meter pegged out when you are on final approach to the runway and need some more power to get to the runway,you apply power and nothing happens.all you can hope for is a real good backfire to clear the ice...thats what they make checklists for...
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41817 |
Venturie principal , air rushing into engine theough a small opening, then expanding creates a cooling effect, moisture in the air condenses out on a cooler surface.
If you have ever drained a tire of air by taking the valve core out of a fully inflated tire you will see and feel the same effect at the valve stem as air rushes out it will form ice on valve stem.
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22824 |
My 45 does it. If it gets real frosty in the winter, sometimes it will cause the engine to not run just right. I put a heat reflector tin shield on it when I need to plow snow. If it warms up at a lower rpm for a bit it doesn't bother much.
I had a 250 inline 6 in a 66 Chevy tuck once that wouldn't pull itself down the road after a cold start and a 3mile drive. I asked anybody I could think of what to do about it other than warming it up at an idle for several minutes. I finally found a guy with an answer by accident. He told me to go to the Chevy dealer and ask for an insulator block for it. It cured the cold start frosting carb. It was just a carb to manifold gasket that was about 3/8 of an inch thick. |
Dave H ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Central IL Points: 3558 |
JW, I think they are tlking about moisture on the outside not on the inside of the venturi?
Yep, moisture on the inside could be a real bummer, specially in a plane.
wkpoor ![]() Orange Level ![]() Joined: 25 Apr 2010 Location: Amanda, OH Points: 825 |
The technical term is Bernoulli's Principle. A increase in velocity of a gas will cause a corresponding reduction in pressure and thus a reduction in temperature to. Typical carb venturi will drop temp 30 degree so 60 degree air can be the worst to from ice because warmer air holds more moisture referred to as RH. Aircraft have a feature called carb heat to help eliminate ice in the venturi at low altitudes with throttle at idle. Old cars like my 69 Impala had carb heat too. For the most part is should go away at higher throttle settings and with warm engine. The closer to closed the throttle plate is the worse the condition will be.
