Model G Engine Drain Plug Washer |
Scott(GA) ![]() Silver Level ![]() Joined: 13 Sep 2009 Location: PeachtreeCityGA Points: 407 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Aug 2018 at 10:50am |
I'm finally starting to work on my herd of Model G tractors.
Yesterday I started draining the oil from G20304. When I removed the Drain Plug I noticed that the Drain Plug Gasket (Part # 800285) was in poor condition. This "gasket" is a thin copper washer. The one on G20304 may not be original and could be a copper washer that was substituted for a correct part. I have an oil pan from a parts tractor and the Drain Plug Gasket on it is not as "wide" as the one on G20304. I can certainly use the one off of the Parts Tractor but I was wondering... Is there a source for a proper Gasket, Drain Plug (Part # 8008285)? I've done a little looking but haven't found anything so far. Scott Edited by Scott(GA) - 13 Aug 2018 at 10:51am |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24338 |
gee, I think I used one for a Harbour Freight 'kit of copper washers'. Whole kit was $10 some time ago.
jaybmiller, That sounded like it had possibilites but I just looked at their site and the Copper Washer Assortment they have now doesn't have an Inside Diameter that is large enough. Thanks! Best regards, Scott |
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 948 |
A lot of Auto Parts stores have an assortment box of replacement oil pan gaskets and plugs. Try a couple stores in your neighborhood to see if they have 1 that fits.
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4755 |
I used some from work that were off the big Cats and Cummins, they were copper too
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53268 |
go to mcmaster carr, and search copper crush washer...
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
I have a sheet of copper. Also a sheet of zinc plated copper. I could make some washers, or sell some of the sheet.
Dusty
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 85532 |
Jim.ME ![]() Orange Level ![]() Joined: 19 Nov 2016 Location: Maine Points: 958 |
A heavy truck service center or an equipment dealer should have the larger diameter washers, if your local parts stores don't.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
I just call my AGCO dealer and get a hand full of them when I run low on them, stops leaks them danged old pan have sitting and making there mark on the floor.
Thanks Gents!
I thought this would be an obscure item but it looks like there are lots of possible sources. Best regards, Scott |
