model c wheel studs
JWCONT1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWCONT1 Quote  Post ReplyReply Direct Link To This Post Topic: model c wheel studs
    Posted: 20 Apr 2011 at 7:06pm
iam i need of help,my c has 2 broken wheel studs.
how does axel come out.
the process would be helpful.
what type of puller will be needed, if needed?
thanks jw
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:25pm
  A good heavy pin punch and a 3# hammer they drive out
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:54pm
You don't need to pull the axle. Just wack then out with a punch and pull new ones in with a lugnut and washer. the wheel needs to be removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWCONT1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 8:21pm
the studs will not back out all the way, becuase of housing.
axel has to come out enough to allow studs to exit.
i need to know how axel is removed
jw
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 8:56pm
Seems like if you have to, you should be able to grind the ends off so that they will push through all the way?
EDIT: Of course that doesn't help you get the new ones in. Duh.
Edited by wjohn - 20 Apr 2011 at 9:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 9:07pm
If you take the cap off the inside of the housing you can get to the nut and inside bearing. to remove the axle you just about have to take the housing off and press apart . when you take the lower pan off. there is a snap ring holding the gear to axle. but there usually stuck and need a press to remove.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JWCONT1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 9:30pm
THANK YOU , THIS MY BE MORE THEN I CAN DO AT MY BARN.
THANKS TO ALL
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 9:32pm
I don't believe there is a snap ring holding the gear to the axle. It's a tapered spline and a big nut and lockwasher holds the bullgear on the axle. There is a snap ring on the axle that holds the bearing cup in place.
    There are 9 parts behind the cap that have to be removed to drive or press the axle out of the bullgear.
     When you get the cap off and the pan off you will see what has to go to press the axle out of the gear. Putting it back together is fun too. You may want to make a special wrench for the big nut
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 5:50am
My C has the same problem. The previous owner just put a couple of bolts in with the nut on the inside. I am going to cut the bolt head off and weld a nut in its place so it looks like a lug and  put a nut on the inside. Should work and look somewhat like the rest.
