Model C Starter Linkage |
DrDirt
Joined: 23 Jun 2012 Location: Newport, VA Points: 7 |
Topic: Model C Starter LinkagePosted: 26 Jun 2012 at 7:51pm |
The two photos show the fixtures for the starter linkage on my 1942 Model C. The rod goes thru a washer welded to a bolt. I'm curious about what the original fixture was.
Joined: 11 Sep 2009 Location: illinois Points: 89114 |
Posted: 26 Jun 2012 at 7:58pm |
mine had a littel U strap under the battery box bottom.
Dakota Dave
Posted: 26 Jun 2012 at 8:05pm |
You also need the correct rod. that is a pull rod and should go to a loop up under the throttle quadrant. the push rod just goes through a L bracket with a hole in it. In the morning I can get pictures of both types. It's to dark in my shed to get any tonight.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6545 |
Posted: 26 Jun 2012 at 8:07pm |
Most likely a piece of metal angle with one side bolted to the battery box mount and the starter rod running through the other side with a return spring, cotter pin and washer installed on the rod if it is the push style. The pull style usually had a u clamp mounted on the steering support post.
Hubert (Ga)engine7
Posted: 26 Jun 2012 at 8:09pm |
Dave must type faster than I do.
MikeinLcoMo
Joined: 12 Sep 2009 Location: west plains mo Points: 620 |
The loop should be 90 degrees to the rod and a spring between the washer and rod clip. I think there is 2 different setups depending on year. You will find numerous variation fabed up over the years.
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Posted: 26 Jun 2012 at 8:52pm |
What size is the "farmerized" cotter pin? Looks to be about an 8D. I've used a few of the same kind in various sizes. Tim |
DrDirt
Posted: 27 Jun 2012 at 8:14am |
Posted: Yesterday at 9:05pm By Dakota Dave
Thanks, That would be appreciated. |
DrDirt
Posted: 27 Jun 2012 at 8:24am |
Posted: Yesterday at 9:07pm By Hubert (Ga)engine7
This is indeed a pull rod. |
