Model C rear rims
Bensjamming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Topic: Model C rear rims
    Posted: 17 Oct 2016 at 11:07am
So after looking closer at the rear rims on my model c I seen they don't have of the wedge or eccentric bolts that I read about most of them having. Mine has a flange with bolt holes that goes all the way around the inside of the rim and has 4 bolts that go through the center cast hub directly through that flange on the rim.
Is this an original AC style rim that came with these in 1942? Also is the only way to change tire width by switching sides with the tires and rims since they seem to have an offset?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 12:12pm
You have after market loop rims. the tread width can be changed by repositioning the rims to the other side of the wheel center. changing the tires to the other side of the tractor the loops are offset in the rim so moving it to the other side changes the offset. turning the wheel centers around and moving the loops either outside the center or inside. so all total you have eight different tread width settings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 8:47pm
Thanks alot. Ya I looked at aftermarket rims and the ones I seen had 4 loops welded to them where as these another ring that goes all the way around with the bolt holes in it. Guess I don't plan on really adjusting the width from where they are at now, but never though of flipping the cast hub around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 10:24pm
Your second description sounds like a waffle wheel rim. There fairly common as front wheel assist rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 8:30pm
I'll have tone try and remember to take a picture of them when I get home. Was confusing me as I'd seen some posts about how to mount the rear wheels and I was looking at mine like you just put the bolts in the hub and rims and tightenjoy. Lol
This page was generated in 0.101 seconds.
