model C power steering
Jerrittcat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerrittcat Quote  Post ReplyReply Direct Link To This Post Topic: model C power steering
    Posted: 13 Mar 2016 at 5:58pm
Just thought I'd share the progress of a resto-mod of a basket case C I bought two years ago for $300...yes I know it has a B front end , but that's how I found it.   After the usual maintenance I got it running and stopping reliably...I set about installing live hydraulics, 3 point hitch and then power steering. The hydraulic pump is just a typical gear type pump that is mounted to radiator support and driven by a shaft through the hand crank hole...hand built a tank and mouted it under the seat along with a single spool valve. Plumbed it up and fabricated a three point hitch system and a receiver hitch for a draw bar. The factory steering box was shot, so I replaced it with the power steering gear box from a KIA sportage.. Had to add a rocker arm to reverse the direction of steering as the kia is exactly backwards. Plumbed it into my hydraulic circuit and voila'...sweet easy and tight steering. It's just a delight to drive now...ready for mowing season to start!
Edited by Jerrittcat - 19 Mar 2016 at 1:47pm
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 6:18pm
Nice setup. I didn't know you could do power steering on one of those. Love the hydraulic upgrade the custom tank look factory under the seat.
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 7:11pm
If it were an original C steering setup, I think you wouldn't have needed
that reversing link. If you have them, could you post pictures of KIA box
installed without the toolbox.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerrittcat Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 7:19pm
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 7:37pm
Wow that's great!
Can I ask you how you added the shaft for the hydraulic pump?
I tried and failed to do the same thing I would be grateful for any tips.
I used a chain and sprocket for my live hydraulics it works but is noisy.
Would you mind if I use your idea for the power steering?
I won't if you prefer I don't thanks.
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 7:43pm
I'd like to see some pics of the pump drive too. What is that front weight from? I've thought of adding live hyd to my b when I get around to redoing it. If I get a pump on I thought of using a hyd torque generator to get power steering.
Burl View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burl Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 8:04pm
Sweet set up ! I am going to make a fork lift out of a CA , your kin thinking solved a few bugs I had . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerrittcat Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 8:22pm
A 3\4" shaft ground to a point fits into crank hole and centers its self
I drilled throuh ears on pulley and pump shaft and pinned it with a 1\4" grade 8 bolt. Mount a flange bearing on inside of radiator support to carry it...adapt other end to pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerrittcat Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 8:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2016 at 10:54pm
That is a cool setup thank you for sharing.
