Model C Hydraulics Help
tiny elvis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tiny elvis Quote  Post ReplyReply Direct Link To This Post Topic: Model C Hydraulics Help
    Posted: 26 Apr 2012 at 9:58am
I am trying to finish my 49' C restoration, and the last thing is the hydraulics. All I have is a cylinder and handle that attaches to the pump. Do I need a valve of some sort ? What does the line hookup to? I just cant figure out what lets off the pressure if the line is hooked up directly to the pump?
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:44am
When you move handle atachefd to pump it will give you three positions , lift -hold - lower  .When in lower position weight of implement pushes oil back through  pump to resovior. before taking pump apart  flush with a solvent  and reprime with oil . It may save you a disamble.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 11:55am
The valve is built into the pump and the handle attaches to the valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tiny elvis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2012 at 1:42pm
Thanks! That is what I was hoping, but I wasen't sure. You guys have helped me alot on this tractor, thanks for all the good advice!Big smile
This page was generated in 0.049 seconds.
