Milling CA head |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4270 |
Topic: Milling CA headPosted: 19 May 2020 at 1:47pm |
I've got a 125 out of a CA I'm working on. Would like to bump the compression a bit. how much can you safely mill off the head? This isn't going to be an all out puller, just want it to be a bit stronger.
Joined: 11 Sep 2009 Location: illinois Points: 90613 |
Posted: 19 May 2020 at 3:58pm |
Dick L had a post a few years ago where he took off about .100 inch ... maybe he will see this post and fill in some info.
CTuckerNWIL
Posted: 19 May 2020 at 5:06pm |
A post on yesterdays tractors, Dick mentioned milling one down .200 , but that left the water jacket a little close.
Here is a post where he mentions taking .150 off. https://www.allischalmers.com/FORUM/b-engine-cylinder-head-performance_topic124536_page1.html Edited by CTuckerNWIL - 19 May 2020 at 5:07pm |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 19 May 2020 at 8:00pm |
Years ago, I sawed one up to find out the answer to that question. You can take as much as you want until the spark plug holes get weak. Instead of milling the head, I now add a dome to the piston. I make and install these myself.
IBWD MIke
Posted: 20 May 2020 at 9:01am |
Thanks for the replies guys. I'll talk to the machinist as well, looks like an eighth of an inch should be doable and would bump the compression a fair bit.
