Military surplus 3500 generator engine in a D21
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Topic: Military surplus 3500 generator engine in a D21
    Posted: 08 Jan 2026 at 10:51pm
I have spoken for a rebuilt military surplus 3500 engine with the intentions of putting it in a D21 with series ll conversion that I have had sitting here way too long waiting for me to rebuild an engine to put in it. I am aware that the timing cover, the front engine plate and hydraulic pump drive will need to be swapped from the D21 engine to the new engine.
 I don't know if the rebuild engine has a crankshaft driven oil pump or the earlier cam driven oil pump, but  will the oil pan on a 3500 engine with the crank driven oil pump clear the D21 front axle without modification?
This rebuilt engine also has a right angle tachometer drive coming out of the tach drive location on the block, so it either has the cam driven oil pump or some sort of stub tachometer drive.
I am also aware that I will need to swap a lot of the engine accessories, most of the fuel system, along with the rear engine plate and flywheel.
I would like to to look as close to "stock" as possible so I plan on using the D21 parts wherever possible.
Any other possible surprises that I may not be thinking of?
Thanks!
Edited by pirlbeck - 08 Jan 2026 at 11:16pm
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2026 at 11:16pm
Steve Fisher probably knows as much about those military engine conversions as anyone.  He sold a bunch of them.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 26 minutes ago at 8:20am
Strip it down to a long block, and go back with the D21 parts as needed. They are both the early style blocks.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 29 minutes ago at 10:17am
I was gonna do this with my 220,, but,,with the help of this forum , hav pretty much figured out that it more than likely has the original engine,, so I'm jus gonna rebuild it..
That being said,, I now have one of these military rebuilds for sale,, still in the crate...
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 54 minutes ago at 1:52pm
if the engine conversation is about the unit Lad/orange knight had listed, this should be the engine tag.. Would not that tag be toward the end of the series? Thanks...Dale
Edited by orangereborn - 11 hours 43 minutes ago at 2:03pm
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 14 minutes ago at 2:32pm
If you want the original Allis Chalmers engine tag on the military block, we stock both the tags and the rivets so it looks original
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 6 minutes ago at 2:40pm
We have put 2900 combine engines in tractors before, so I know there is a fair amount of parts transferring to be done.
Thanks for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 2 minutes ago at 2:44pm
My block has a hole in it behind the hydraulic pump so there is no rebuilding it. When I bought the tractor it came with a short block that looks like it has sat outside with not head on it. My intention was always to just rebuild it, but as expensive as parts and machine work are I think this rebuilt engine will be a cheaper way to go.
Thanks for your input!
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 51 minutes ago at 2:55pm
Yes, the engine is the one in the classified here listed by Lad.
Besides the factory style tag on the rear LH corner of the block, the picture also shows another tag farther forward on the LH side........maybe this tag has some rebuild SN or component information. If it is that late of production engine, would it likely have piston cooling jets in it?
Thanks for your help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 40 minutes ago at 3:06pm
I will keep that in mind, depending on how original it ends up looking. Can you stamp the tag?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 26 minutes ago at 3:20pm
Well,, a hole in the block don't leave much choice mine still run,, although it's really tired,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 56 minutes ago at 3:50pm
Are you in New Mexico? I am going to be driving through there in a couple of weeks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 22 minutes ago at 5:24pm
Lad sent me a picture of the tag and as you stated, it is the same date of MFR and the same engine SN as your picture above. Is the date of MFG and the engine SN the original one from Allis when the engine was built? I would think it would be.
Anyone know what the A suffix means in the model number?
The other tag shows the rod and mains as being .010 & .010 and overhauled at OSMS, OREGON
Thanks!
concretepumper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concretepumper Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 56 minutes ago at 8:50pm
I have done this swap on 2 d21s and a 210, the ones I have swapped in all had the front crank shaft driven or 210 style oil pumps
As ed mentioned, I stripped the long block down and exchanged rear covers
If the motor is crank driven, you will need a deep 210 style oil pan and front cover
The deep oil pan does clear the front axle
One of the differences I found are the cranks do not have dowl pins for the flywheel, they have Japan cranks, and standard rods
One thing I would for sure check is the oil cooler, finding out the hard way, sitting in storage, the copper in the cooler had deteriorated and upon start up, mixed coolant with the oil
Other than that, pretty straightforward, I use one in a 210 pulling hot farm class
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 50 minutes ago at 9:56pm
The suffix "A" would mean it is a first generation 3000 series engine. This would mean the oil filters are positioned to run oil down the side of the block when you remove them and if equipped with an oil cooler (turbo'd engines) it is vertical in location right behind the injection pump. Typically, we would see them in D-21, 210 and 220 farm tractors.  I don't think piston cooling jets would be there as the cam driven style oil pump didn't have enough GPM's for that feature, or maybe they blocked the jets with the blank main bearing shells? . The crankshaft driven pump was the same as a 7030/7050 tractor which the 7050 has piston cooling.
Edited by DrAllis - 3 hours 42 minutes ago at 10:04pm
