metro speedometer?
Message Reverse Sort Order
ocharry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Topic: metro speedometer?
    Posted: 08 Feb 2017 at 10:19am
hi dale,,
i asked bob's about that and they recommend wheel bearing grease,,,,it gets cold here and that seemed a little heavy TO ME,,,,,so i cleaned it off with mineral spirits and then i used a lubraplate white grease
Bob's said if you use to light of lubricant it will migrate into the tach and mess up the works,,,,,,so i kinda split the difference (i think) with the lubraplate,,,still grease but not as heavy as wheel bearing grease,,, seems to be working fine,,,bounce in the needle went away too
that is what i did,,,,YMMV
ocharry
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 8:13pm
Ocharry, what did you use to lubricate your cable?  Thanks Dale
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote ocharry Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 11:39am
yeah i just got mine back from bobs a couple weeks ago,,,i think they did a great job,,looked new when i took it out of the box
price was a little high for what he had to do,,,but i have the original and it looks good ,,works good,,
while it was gone i pulled the cable and cleaned and lubed it,,,running smooth and true,,
bob also turned it around in a week,,,it was gone for 8 days from when i mailed it to when i opened the box,,,that was nice
ocharry
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 5:50am
I have used these guys with good luck
http://www.bobsspeedometer.com/1/120/index.asp
1968 D15D,1962 D19D
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2017 at 1:53pm
I'm sorry to say they are gone. They did good work for years and will be missed.
orangeman69 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman69 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2017 at 11:05am
anyone know what happened to metro speedometer in independence mo.? I sent them 3 allis tachs to be repaired and they got returned. phone is disconnected. they were awesome at fixing tachs. web says permanently closed. kinda wondering what happened.
d17,d17nfpuller,d-17IVdiesel,d19gas,d19diesel nf,d21seriesII,180,190xtseries III,200,210,7020,7060,7080w/8.3cummins,8070fwa w/8.3cummins,8550 185 w/322 original hrs.
