Manifold studs, washers and muffler bracket - WdD5 |
Brampton 02 gt ![]() Orange Level ![]() Joined: 07 Apr 2011 Location: Erin,ON, Canada Points: 321 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Dec 2011 at 9:00pm |
I am re-assembling my engine and wondering if aneed to use washers on the manifold studs.
I have lock nuts I bought from Agco, but the new manifold (aftermarket made in taiwan apparently!) looks like there are grooves or at least a small polished area for a flat washer. I assume I should ude washers on the stud with the split casting? Also does any one know what the proper muffler bracket is? is it the three piece version - with a band clamp an one piece that connects to a head bolt (came with muffler and was on the tractor when i got it) or is it the single bracket which I also have? I assume I must have to "massage" the end of the new muffler to fit into the new manifold. Should the muffler rest on the muffler bracket bolt? thanks. I am getting close to starting the old girl. I will post pics. |
It is a WD45. not a Wdd5
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2259 |
I used brass nuts, stainless steel washers and copper based anti-sieze when I replaced the gaskets on the manifold on my WD.
It might sound like overkill, but I don't want to have any hassle if I ever have to take it apart again.
Orange Tractors ![]() Silver Level ![]() Joined: 13 Sep 2009 Location: Butler, MO Points: 172 |
I also painted the studs and the holes in the manifold with anti-seize when I replaced the manifold on my WD. The old studs were rusted to the manifod so bad that even if I could have gotten the nuts off, the manifold wouldn't slide over the studs.
Robert
I forgot to say what Orange said; some of the studs go into the water jacket.
I recommend coating the threads that go into the head with Permatex #2 before installing them to assurethere is no leakage.
Good idea - I will do that as well. thnaks
did you guys use washers with the nuts?
Yes, use washers. They help to spread the clamping force of the nut.
Robert
