Magneto spark
Larry in Ill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in Ill Quote  Post ReplyReply Direct Link To This Post Topic: Magneto spark
    Posted: 20 Sep 2012 at 7:55pm
I'm testing my spare magneto and can only get a spark on cylinder 2 & 3.  It has a good spark so what could be the problem?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2012 at 8:03pm
When you flip it around, does it spark every time you flip it a half turn but just spark off 2 or 3 or does it skip a spark twice in 2 revolutions?
Guests View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2012 at 8:13pm
what magneto? an RV4 or RV4B has a specific set of possibilities Which model do you have??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in Ill Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2012 at 9:07pm
It is a fm j4b3 and it sparks every other cylinder.  I bent the copper contacts closer to the rotor thinking the rotor was bad, and one sparks, but the other is still dead.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2012 at 6:05am
Any time I have had a magneto give a good spark on one or two wires and not on the others it was solved with a new or different cap.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2012 at 7:18am
Are you hand cranking ?????  inplause may not be working at cranking speed.What do you call testing and how are you going about the test ??
What mag ? ,all B,C,CA, WD, WC ,  spark in rotation,unless it is a RV4.
Edited by Fred in Pa - 21 Sep 2012 at 7:22am
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in Ill Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2012 at 8:09am
It is for a C and I was hand cranking the engine.  I took it apart this morning and have an intermitent spark at the points.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2012 at 12:54pm
Could be one of the pawls is rusted fast or rounded and not holding on the stop pin under the spring.
That would cause spark to skip a plug  and spark the next.
