Mag help |
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 999 |
Topic: Mag helpPosted: 27 Feb 2012 at 10:00pm |
I need a little advise on the magneto on my M. I have spark for number 1 and 4 but not for 2 or 3. I took the cover off, cleaned it up, put it back and still nothing. I forgot to write down the number on the mag, but I will get it tomorrow.
Thanks, Joe
Life is simpler when you plow around the stump.
Glockhead SWMI
Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Posted: 28 Feb 2012 at 5:07am |
most likely cap or wires. possibly plugs.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12043 |
Posted: 28 Feb 2012 at 6:04am |
Probably an H4 Mag. That problem could be as simple as a bad plug or two. Do a continuity test on the wires and make sure the wires are okay. Hairline crack across the end cap from opposite terminals would cause a misfire on two cylinders also. Might need a magnafing glass to find the crack in the cap unless the tracking is evedent. Moisture under the cap can also cause that problem. HTH Steve@B&B |
Joe(OH)
Posted: 28 Feb 2012 at 3:05pm |
The mag is an American Bosch MRF 4 A 322. Can parts still be found for these?
Glockhead SWMI
Posted: 28 Feb 2012 at 3:20pm |
http://www.magnetoparts.com/cat_index.htm
