MACK fire ring questions
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: MACK fire ring questions
    Posted: 31 Jul 2020 at 7:12am
Finally getting around to building our 262.  We got fire rings from you and I was curious what the crush on them is so i can get an idea of head clearence and according to your directions the soldered joint goes away from the cam side. Correct?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 9:45pm
They will only crush to the thickness of head gasket. Rings are .075 and gasket is .065 so ring crush is .010 + stand out of sleeve.        MACK
This page was generated in 0.091 seconds.
