M3 automatic vs manual unload auger
Wade (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Topic: M3 automatic vs manual unload auger
    Posted: 10 Nov 2015 at 1:42pm
Does the automatic mode work with auger going out and when it folds in? Is it controlled by the roller switch on the housing and the lever switch on the cradle? The auger has tried to turn on before it was fully out and I'm thinking it's one of the switches?
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2015 at 1:55pm
What do you mean by the auger has tried to start before its out? The automatic mode is just for swinging the auger out and in. You have to press the switch for the auger to start(assuming it has the electric/hydraulic control). If the auger is starting before its out either the roller switch is misadjusted or is bad. The roller switch on the swivel is what controls when the auger can come on. The switch on the cradle is just for the auger out light.
ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2015 at 2:53pm
Ok, I'm betting the roller switch is my culprit
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2015 at 6:11pm
Fix it before you have to repair the auger because it started to soon and busted s...t up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2015 at 6:35pm
Too late, broke the knuckle u joint!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2015 at 7:35pm
sorry  been there fixed that
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 1:55pm
on my L3 the auger swing is separate from the unload switch, if you leave the auger running when swinging back in the micro switch shuts off the auger, I never started unloading until fully swung out and always tried to shut auger off before swinging in
Jim NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 5:06pm
Look that micro switch up on line.They are $7 on line and $56 at Agco
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wade (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 7:07pm
It seemed to start before the auger was fully extended.i need to get the old switch off to cross a matching replacement.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 8:51pm
Wait... so on some combines when you push the switch for the auger out, when it gets out the auger automatically engages?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2015 at 9:09pm
No. Auger only turn on when you push the unload switch. If it comes on by it's self, you have a wiring problem. The limit switch keeps you from turning it on until the auger is out.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2015 at 8:47am
Ok....I misunderstood. I thought that'd be pretty strange.
