Lowering Allis WD
Foolster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foolster Quote  Post ReplyReply Direct Link To This Post Topic: Lowering Allis WD
    Posted: 31 Jan 2021 at 5:48pm
Does anyone know of someone who has lowered a WD or WD45 by rotating the rear spindles forward and then building a beam front axle to lower the front to match?
I am in the process of doing this with a B and wanted to do it with a larger tractor.
On our cherry farm in Michigan we bought several David Brown tractors from the factory with the rear differentials rotated to lower the tractor for orchard use.
Edited by Foolster - 31 Jan 2021 at 5:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 5:57pm
Pretty easy to do I think. You'll have to drill a new hole for the bottom brake shoe pin, but other than that it should be easy.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 6:01pm
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 6:38pm
I think tbran has done that. Maby he'll chime in.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 8:16pm
Did it years ago. No need to drill a new hole. Make new pins 1 1/4 shorter, drill and tap pin for slide hammer, install final drive and brakes, rotate final to your position and install bolts.  More than one hole, you should reseal top axel .         MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 9:49pm
6 bolt pattern inboard end .............. you rotate 60 degrees ?
OK... are there 8 bolts at the outboard end ?
Edited by steve(ill) - 31 Jan 2021 at 9:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2021 at 9:52pm
If you choose to cut off the lower brake pin instead of drilling a new hole, you cannot use axle studs. Use all bolts.
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 5:44am
brakes ?? tractors have BRAKES ???? WORKING BRAKES ?????? Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 8:29am
Do we have pictures?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 8:31am
Rotate final drives don't effect brakes.           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 8:43am
Don't you have to do some creative engineering to "pull" brake rod with finals rotated?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 9:06am
Nope. The brake mechanism and linkage is inboard.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 2:37pm
We flipped the finals  upside down - keep in mind there is a vent hole that will let oil out on WD-185 finals. Either pull the pan and plug the vent and pack full of EP-O grease.
Edited by tbran - 01 Feb 2021 at 2:40pm
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 5:24pm
Don't that look like something Herman Munster would farm with
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 9:13pm
tbran,
Well isn't that sweet! Thanks for the picture. Had never seen one lowered!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 9:20pm
each final drive gear box can be rotated seperately from the extension tube... unlike the smaller B,C tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2021 at 10:58pm
So the flip is at the outer end? that would explain the brake "no problem"
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 5:58am
great, now I'm thinking of lowering one of my D-14s.....
hmm..anyone got pictures .....
might make and interesting all-summer-long project ,since I sold next door and have zero need for any of the orange and implements....
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 7:35am
No Steve, you flip it at the inner housing. All the brake parts are in transmission housing, only drum is on final.              MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 8:39am
OK... but now i still have questions... -- WHY at the inner housing... and second, i thought the inner flange had 6 bolts ?  so you can FLIP 180 degrees for excessive drop, but you can rotate only 60 or 120 degrees to "lower" somewhat ?
the WF was "different" so it had housings cast 90 degrees rotated.. and narrow ??
Edited by steve(ill) - 02 Feb 2021 at 8:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 7:35pm
Mack, DR... Why can you not rotate the outboard housing 90 degrees ?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2021 at 9:21pm
The outer bolt pattern is not evenly spaced. Might work at 180 degrees, have not measured the spacing.                MACK
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 5:46pm
Now I'm curious.  I have a WD just sitting here I was thinking of selling this spring.... hmmm, would be cool to lower it..... darn it, I have too many things to do now... LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 6:31pm
Leave those outer bolts alone !!  They are too hard to wrench on and they must be TIGHT afterwards or they can work loose.  Also unevenly spaced like Mack said.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2021 at 8:25pm
I think the INNER bolts are quantity 6 ?  So you can FLIP the axle housing and lower it about a FOOT... ON the IB you rotate 90 degrees and only drops 6-7 inches.. I guess you could rotate it 60 degrees and the housing would set at an angle... maybe lower the tractor 5 inches and move the axle forward 5-6 inches ???  Would that work ?  Anyone ever done that ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2021 at 8:34am
Well I feel stupid. I've had the housings off the trans/rear,done the whole brake thing and all and couldn't figure why the brakes weren't an issue. DUH! Now you got me thinking about a "project"!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2021 at 9:34am
dang I'm still thinking about lowering one of my D-14s.....
GREAT summer project..
so....anyone every seen a lowered D-14  or will I be the first ?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2021 at 12:20pm
Jay
Took a peek at my D-15 rear axle housings. Looks like your thought might be feasible.
The Final Drive Housings are attached to the Differential Housing by only 4 studs, and they appear to be equally spaced.
One thing I noticed is the Diff. Housing does not point straight down, but instead angles rearward perhaps around 30'.
Obstacles you would have to overcome:
- the Brake Actuator would be pointing forward instead of down
- the Fender Mount would be pointing Skyward instead of Horizontal
- you would loose the rear support for the Floorboard
Access to getting on the Tractor could be difficult with the Rear Tire moved forward.
Good luck
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2021 at 12:40pm
gary...
you'd think I'd remember this stuff, having removed BOTH axle housings to do brakes last summer....
sigh...
yes 4 bolts 90* apart,so 4 ways to mount..
maybe swap left for right, gets the brake control accesses 'normal'
fenders.hmm..ok, 'minor' bodging there...
no need for floorboards...it's already LOWERED..........
dang, I'm kinda getting into this....
'first onthe block with a lowered D-14'...
Jay
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2021 at 9:23pm
It don't change brake actuator. Just have to notch axel housing for brake linkage.          MACK
