loss of drive
DAK2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DAK2 Quote  Post ReplyReply Direct Link To This Post Topic: loss of drive
    Posted: 12 May 2013 at 4:50pm
  I have a 190xt 3 and today i was plowing and would temporarily lose hydraulic pressure i guess the steering would get hard and the 3 point hitch and cylinder on the plows would get choppy and not work when this all would happen the tractor would not move then all at once it would take off ,check the fluid full even after i unhook the plows it still acted like it was jumping out of gear or into neutral then back in gear i kind a think maybe the main pump is going out has anyone else ran across this before
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2013 at 9:49pm
Did you check the oil on left side of gear shift? It sounds like low on oil. If it is full, check all the clamps on big suction from bottom of torque tube to pump. If it is a early 190XT, pull the flow divider out of manifold on back of pump, polish it.   MACK
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2013 at 9:59pm
When I saw the post I thought you were talking about me. My wife says I have lost my drive to get things done around here.......LOL
                                                        IG
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2013 at 10:59am
I thought the same thing when I looked at the subject line. I do suffer from that and need a fix. Too many projects and not enough drive.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2013 at 11:07am
mine just did bout same thing  only it would move fine   i polished flow divider and rebuilt my hyd. pump  works great now   not saying you need to rebuild pump though .
       Shawn
190XT,D17and 7045
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2013 at 11:33am
I got plenty of drive, but seems like the projects just keep gettin stacked on, so as not to be able to get ahead of the curve!
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2013 at 11:52am
When I saw the post, I was going to suggest Viagra or Cialis.
"People are human beings, produced by the society in which they live. You encourage people by seeing the good in them." ~ Nelson Mandela
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2013 at 7:11pm
Cialis ? You mean C Allis? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2013 at 6:31am
That's funny! I thought the same thing when I read the title line. I guess us old guys automatically think that way. Glenn, you need to take some of that drive and start hammerin' at your projects before the drive goes away! C'mon son, git' wit' the program! Stop pilin' and start doin'!  LMAO!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2013 at 9:32am
Steve,
I ain't the one doin' the pilin'!!!
Workin' like a dog, gettin' a lot done, but can't work faster than rate the pile is growin'...
I think I need a couple more tractors to help take some of the work!
