Loose fan |
jazzsuds
Topic: Loose fanPosted: 27 Apr 2017 at 3:21pm |
I have an Allis Chalmers 7040 and the fan is slightly loose. Do I just tighten up the bolts holding it on or is there a bushing that needs to be replaced?
mattb
Posted: 27 Apr 2017 at 3:22pm |
better check your water pump bearing
MACK
Posted: 27 Apr 2017 at 4:45pm |
Replace water pump before fan goes through radiator. MACK
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12336 |
Posted: 28 Apr 2017 at 6:58am |
Like Mack says......I suppose there is a very slim chance it could just be bolts, but unlikely.
ocharry
Posted: 28 Apr 2017 at 12:46pm |
i was gona say the same thing Mack did
you could check the bolts but if that shaft come outa that pump housing its gona be UGLY ocharry
jazzsuds
Posted: 28 Apr 2017 at 2:51pm |
Thanks Gents. I bought a new pump. Anything I should be aware of when I do the replacement?
farmboy520
Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Posted: 28 Apr 2017 at 2:54pm |
You might want to change the thermostats while it is drained down so you know there won't be an issue later
Posted: 28 Apr 2017 at 3:45pm |
Good luck getting the aluminum fan spacer off the nose of the water pump hub.
