Locking Collars On Bearings ? |
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Aug 2021 at 6:15pm |
There's a a post on NAT about the "collars" on the bearing/shaft. A guy claims that the cylinder bearings on an L2 machine does not have the collar, only red LokTite to hold those bearings in place . Is he correct ?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21399 |
Loctite red or green is a good idea. But, the truth is each side of the threshing cylinder has a nut on the end of each shaft. The nut squeezes a hub up against the side of each bearing keeping them from creeping on the shaft. Thus, no lock collar is needed.
Thanks for the clarification Doc
