Lining battery box? |
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2678 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Aug 2012 at 9:46am |
Is anyone lining their battery boxes in case the battery leaks? I have had problems with both of mine and have messed up my paint. Any ideas? Thanks Mike
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
1957 WD45 dad's first AC
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11994 |
Years back Honda cars came out with a little plastic Battery tray that goes under the Battery. As time progressed, some of the other mfrs have followed suit. Probably could find one of those trays to fit in the AC Battery box. This way anything expelled from the Battery winds up in the plastic tray and not running down the side of your nice paint job.. Just a thought.. Might even be able to find a Tupperware container that you could cut down that your Battery would fit in. Viola! Self contained Battery box, in the Battery box! No muss, no fuss, no mess....
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
Any thing you can line with will just be a cover up. Acid will get behind it and eat it out anyway. The reason batteries leak is because your tractor chargeing system leaves much to be desired. Their was someone making stainless steel battery boxes a while back I don't rember who. I put Optima's in they don't leak. and last forever. I'm going to need to replace one before winter but it's been in the tractor since 1992.
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Don't over fill the battery and it won't boil over.
GlenninPA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Steve Jelf |
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5900 |
I have a plastic Battery Box meant for a Boat on my D-12.
Gary
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
I guess someone could be profitable if they could manufacsure orange plasic battery boxes that resemble the original?
I have one of the stainless steel boxes for a WC that I never used. For sale if anyone needs one. PM me! Edited by john(MI) - 09 Aug 2012 at 11:08am |
MilesGray (CO/KS) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: CO/KS Points: 729 |
I know Steve still has them for sale, not sure what he's wanting for them though.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
I understand that batteries shouldn't overflow but one was a bad battery that came with the tractor, the second was a good battery that I made a mistake with! That being said I am not by my tractors for a couple of weeks at a time and was looking for something that if it happened I would have some protection until I fixed the problem. I don't think I am the only one that has had this problem. Thanks for the suggestions. Mike
ctbowles58 ![]() Orange Level ![]() ![]() Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
I SPRAY THE INSIDE OF THE BOX AND LID WITH TRUCK BED LINER. WORKS WELL AND YOU DONT SEE IT ANYWAY.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
patrickmull ![]() Orange Level ![]() ![]() Joined: 11 Jan 2011 Location: Casey IL Points: 893 |
i use optima batteries i have one in my boat that is a 2000
Bryan ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 463 |
Use a dry cell. No corrosion or leaking. Cost more, but worth it.
I put a sealed Deka brand 12v in the C but my WD-45 is 6v and I don't know if they would make a sealed battery for it. But I already have a 6v Deka to put in it.
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
second ctbowles, i also sprayed on bed liner when I built my box, should last years
PlayGun ![]() Orange Level ![]() ![]() Joined: 18 Jul 2012 Location: Bulls Gap, TN Points: 399 |
I use Line X stuff from Oreilly's or Tractor Supply.
Hopefully Future AC Man! Ride With Jesus my friends! Lonas
