lift cylinder tear down |
WI Dave ![]() Bronze Level ![]() Joined: 30 Jun 2020 Location: WI Points: 12 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Jul 2020 at 1:59pm |
big bore lift cylinder 185 Allis
I am sure it is already on here but I have not used the correct words to find an answer. How do I get this thing apart?
Gary(VA) ![]() Silver Level ![]() Joined: 13 Sep 2009 Location: Troutville, VA Points: 341 |
Take off the 90 degree elbow. With the cylinder collapsed you should see a snap ring. Move it into the lower groove in front of it. The ram will them slide out.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22010 |
Rotate the rod while you pry the snap ring to the smaller diameter groove. Reverse procedure to assemble.
This looks entertaining.... Pin stuck about 3/8 inch out before I started, don't want to go in or out.
In the middle of moving my shop so it will be a bit before I can tie hard into this for now. No way I am going to get that ring without complete removal of cylinder. I need to change brakes so I will attack this when I tear down for that. Thanks everyone. I appreciate it. Edited by WI Dave - 04 Jul 2020 at 6:05am |
