LIFT ARM LATCHES |
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2584 |
Topic: LIFT ARM LATCHESPosted: 19 Oct 2016 at 11:10am |
CAN ANYONE THE ME WHAT THE BAR WAS USED FOR THAT GOES BETWEEN THE LIFT ARM LATCHES?
THANKS, DAN
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24890 |
Posted: 19 Oct 2016 at 11:15am |
I know an 1 1/4" bar fit them but DON'T use too lift a really,really heavy thing with the bar....it'll bend...sigh....
I'm thinking it was to keep the latches 'rigid' to each other ?? someone WILL know for sure ! One of my D-14s has it, the other don't.... Jay |
Posted: 19 Oct 2016 at 12:04pm |
I believe it started with the early D-17's and maybe even very late WD-45's. It added side-to-side strength between the lift arms with heavy mounted plows.
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2724 |
Posted: 19 Oct 2016 at 1:02pm |
I use the lift latches with bar in between them when using the AC SC #109 disc. It helps with sway control and is easier on the arms when the disc is lifted.
Unfortunately, it can't be used when I hook up my SC #73 plow. Then I have to use some individual lift latches on each arm.
dawntreader74
Posted: 19 Oct 2016 at 11:05pm |
getting off an on the tractor' all it was for is to get someone HURT' tripping on that junk time after time.
