Leveler bar on a field plow?
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Leveler bar on a field plow?
    Posted: 23 May 2012 at 9:32am
Grandpa had a neighbor who pulled a 5 bottom with a 190 that had a solid spike bar on it, anybody ever seen this? what was its purpose? to eliminate the need for harrowing or disking?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:43am
I have seen pictures of it.  Looked like it did an OK job.  I have also seen a cultipacker pulled behind a plow.  They had better soil than I do though.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:43am
Our neighbor used to do this and he would plant right after he plowed, no disking or harrowing.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 10:32am
Was still done in the Dakotas that way up to about 15 years ago. Spring plowing with a plow with 14 inch bottoms with the buster bar. Roll in right behind with the corn planter or drill. Some guys pulled the drill right behind the plow. The JD 750 made no-tillers out of everybody.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 10:40am
I have two bars of spring tooth on my disk and 3 bars of spring tooth on my field cultivator. The spring teeth on the disk cut the passes to make a fine seed bed from 3 to 2. And the spring teeth on the FC levels out the ridges it would otherwise have left.
Gerald J.
Edited by Gerald J. - 23 May 2012 at 10:40am
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 12:58pm
Yep, Buster Bar.  Have one on dad's 9000 series 4-16 plow.  Does a real nice job of breaking up lumps before they can dry out and get hard.
The innovators offer what others will imitate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 2:01pm
anybody have pictures of one in use and the results of them?
German Shepherd dad
#WD234847
#WD88193
