Let's talk tires.
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Topic: Let's talk tires.
    Posted: 29 Jan 2012 at 12:37pm
Got a couple of tire related questions.
1)  I've got a couple of rear tires that leak down over the course of two weeks or so.  Is it worth putting that slim stuff in them to seal up the leaks?  Secondly, the sidewalls look sort of rough, almost like the tread "caps" are separating from the sidewalls.  The only way I can describe them is with my wife's term...scaly tires.  The tread is about 75% if not more.  I'd like to keep running them; are there any safety concerns.  They don't carry a lot of of weight, but do see some hard pulls skidding logs on occasion.
2) When did the old style closed bar tread pattern tires stop being standard?  Did buyers have an option of closed or open tread?  What year tractors would they be "correct" on?
AC - WD
JD - 650
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 12:45pm
If there tubeless the Green Slime will work but if tube type check the valve area first for leak with soap and water for leaks. Might try full tire with soap to see if you can find the leaking area . (used slime in bicycle tubes but never tried it in tractor or truck tubes, easier to replace )
 have used the slime in my backhoe tires and works well .
Which tread as the R4 is industrial tread and there are several AG treads also.
If it is a tubeless tire might be easier to install tube . Before I put new tires on TLB I had one with spot in sidewall I booted and used a tube.
Edited by Coke-in-MN - 29 Jan 2012 at 12:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 12:49pm
Old pair by Armstrong.  R1 tread.
Edited by OrangePowerGA - 29 Jan 2012 at 12:49pm
AC - WD
JD - 650
millertire View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote millertire Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 5:36pm
What size tire do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 5:54pm
If you have tubes and they're leaking by the valve stems, put new valve stems in the tubes.   Some of the older tubes, the entire stem part comes out, there are at least two different styles.   YOu can buy new ones and thread them in and your leak is most likely solved.
Here is a link to one style at Gemplers.   I have both styles on hand in the inventory.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 6:12pm
13.6X28
AC - WD
JD - 650
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2012 at 6:29pm
alot of times those little o-rings dry up and crack letting air seep out. they're the ones that have a nut holding them in place, have had to replace several on my truck and backhoe thru the years..cheap easy fix.
