lets play guess whats wrong!
Brad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Topic: lets play guess whats wrong!
    Posted: 06 Dec 2011 at 5:00pm
I have a 704560 (front half 7045, rear half 7060 ps).  Neither had run in maybe 3 years, so I spliced them together.  7045 ran great when parked, and 60 had strong trans.  When I put them together, it didn't run as well.  I used it to pull an irrigation rig to the field and back, then to another farm.  It had a bad miss, and a lot of white smoke, I assumed from the missing cylinder.  I drained the fuel and replaced with fresh with a injector cleaner.  Still ran poor.  I assumed a bad injector or two, so I replaced those.  Still just as bad.
  Now for your guesses.  I found out the problem today (I think!).  It is not fuel related.
Remember:
 1)ran when parked!  we have all heard that, but I am the one who parked it.
 2)Sat for around 3 years
 3)We  also have a 7030, 8050, and I had a D21 puller at that time.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 5:13pm
I  think the air cleaner was full  of mouse nesting material.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 5:15pm
Pluged up air filter from mouse nest?
R.W View Drop Down
Gary beat me too it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:00pm
neither one, keep trying.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:04pm
Mouse nest in the pump causing bad injection in at least one cylinder accompanied by an injector line leaking from having almost rusted through due to another mouse nest.
Gerald J.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:25pm
C'mon guys the answer must lie behind clue #3! lol can't take the suspense!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:27pm
Getting warmer, captaindana!
ACscott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACscott Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:29pm
mixed up parts from the other tractors and put them on this one?? actually maybe not but thats all I could get from clue #3, after I posted this I remembered they all had the 426.
Edited by ACscott - 06 Dec 2011 at 6:35pm
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 6:37pm
Somebody put a CaseIH decal on it?? lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 8:00pm
When I started it after the new injectors, I had to crack the lines.  That's when I heard the louder than normal valves.  One must have had extra clearance I figured.  Today I took off the valve cover, put the engine at TDC and wiggled the rockers.  I didn't have my manual there, or a feeler guage, but thought I would be able to feel one that made that much noise.  I sure did.  One lifter had excessive play, mostly due to A MISSING PUSH ROD!  I remember bending one on a tractor once (I think the puller), this must be where the replacement came from!  I actually think I borrowed it from the 7030, as that tractor is never used.  When to 7045 went down, I maybe took it from this tractor to replace the 7030's.  Not sure exactly how it went missing, but it sure is gone.  I bet it will have a little more power now.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2011 at 8:36pm
  Hello Brad   Simiular case.  Went to a sale looked at a newer B very good looking tractor and mounted plow started good but had a definite miss figured that someone moved the spark plug wire, long story, bought it brought  it home and told my son to make it run, he said the electric was correct but #3 wasn't firing , bent push rod, had one on shelf runs great still a good buy at $800
