Left hand feed implements.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Topic: Left hand feed implements.
    Posted: 31 Aug 2019 at 7:22pm
What was AC's reasons for building combines,rotobalers and other equipment that had left handed pickups?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 8:51pm
Could it be because binders were left-hand cut, so they just kept building things that way?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2019 at 9:11pm
The left side works better for me with hyd and hand clutch on all crop(WD45). Yes you set crooked in the seat but it wouldn't work in reverse.
Edited by SteveM C/IL - 31 Aug 2019 at 9:12pm
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 7:37am
Because "right side" was already taken?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 7:44am
When you sit on the right side of the tractor, like the WC, it's easier to turn to look to the left, than it is to look right.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 9:22am
Why didn't they make sickle bar mowers cutter bars be on the left side?
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 1:42pm
Road frontage. You'd be against traffic. Municipalities used to use sickle bars to mow along the public road ROW.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 2:30pm
The corn binders I'm familiar with were right hand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 2:42pm
I guess the geographical difference explains why I've never seen a corn binder in person. I had grain binders in mind.
200Tom1 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 4:38pm
Round balers were on the opposite side because they worked better with the hand clutch. After baling 10's of thousands of bales with a round baler, I bought both an IHC and Deere square baler. I hated using them. Did the AC small square balers have the pickup on the same side as the Deere/IHC?
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2019 at 8:09pm
I ask my neighbors this question all the time. They have 5 roto balers and I have 1. They still bale around 4-5000 small rounds a year use to routinely due 15000. In any case it never made any sense to me to have it on the left side. I grew up on WD's and I don't care what people say it would be a hell of a lot easier to look over my right shoulder for the pick-up on the roto. I heard one argument from someone well you its because when you get off the tractor on the left side you are there to work on the feeder. that makes no sense because you get on the WD and 45's from the back of the tractor. Never heard a valid reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 10:02am
 I doubt the hand clutch had anything to do with it, since the roto baler was in production before there was a hand clutch  or a WD.
 Allis square balers were right side pick up like other makes of the period.
Edited by CTuckerNWIL - 02 Sep 2019 at 10:03am
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 7:17pm
I would guess that back then, right or left hand as a standard hadn't really been established yet, so companies were still dabbling with what worked better. I have no qualms about my roto baler feeder being on the left side. darrel
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2019 at 9:21pm
There might be some validity to that point when you really think about it. When you get off of a tractor on the left, most people would prefer to walk straight back to the implement to address any issues simply because it is easier that way. With right hand feed implements, the operator either has to walk around the front of the tractor or step over the pto shaft at the rear to get to the feeder unit on the right. Even with a "W" series tractor or any other brand of that same vintage for that matter since most were rear mount/dismount back then, you dismount to the left of the pto shaft so the above argument is still valid. As an AC enthusiast, I'd like to think that AC was thinking ahead concerning farmer safety but that would be hard to prove unless some of those engineers are still around.
