Leaking 3 point lift Cylinder Fix? |
GlenB(IA) ![]() Bronze Level ![]() Joined: 11 Sep 2009 Location: Iowa Points: 127 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Jun 2016 at 5:41pm |
I have a 185 with a lift cylinder on the 3 point that leaks pretty bad. Does it take much work or money to rebuild them, or should I hunt down a used one? Thanks! GLEN
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34224 |
Buy seal kit...
easy to change if you know how... Fat cylinder, work through hydraulic fitting hole to remove internal snapring... then pull out, and replace seals then reverse proceder... small rod cylinder, use spanner type pin wrench and remove end collar... seal packings should have instructions with them for replacement. If rod or cylinder is scored, find different cylinder. |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7445 |
A good hydraulic shop can fix yours up. Any used one you find will probably leak as bad (or worse) than the one you already have.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8256 |
Had one done at the dealership close to me ran around 85 bucks, easy to do for experienced mechanic
lowell66dart ![]() Orange Level ![]() Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
I did my 200. Never done any cylinder before. Fairly simple.
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Is AGCO the best source for the repair kit? Others? Thanks!
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1020 |
I did both cylinders on my 200 last year. Got the parts from AGCO and were not bad on price. Biggest job was removing the cylinders and that wasn't too bad. Putting the seals in was kinda like a woman's head--NOT MUCH TO IT
I used AGCO parts. Pay attention to how the old seals are orientated. In my case they were in pieces.
Allis_Cooper ![]() Bronze Level ![]() ![]() Joined: 05 Oct 2021 Location: FL Points: 23 |
I have a 185. The lift works okay but slowly goes down once in an upwards position. Could someone advise me here? Do you think the lift cylinders need to be rebuilt?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21416 |
If your lift cylinders aren't leaking oil on the ground, they are fine. "Settling" of the hitch with a load on it is fairly common. How fast of leak down and how much weight ?? If your hydraulic linkage under the hydraulic console is functional (many are rusted up and stuck) pulling the POSITION CONTROL lever all the way back will keep the hitch up while the engine is running, but not with engine off.
Thanks for the quick reply. With a disk harrow lifted it will fall down say within 30 seconds so that you have to re-lift as you drive. Yes, I have noticed if I leave the lever all the way back it stays up. However, this seems to produce a leak under the hydraulic housing so I have been avoiding it.
On the rear of the lift/lower 3-point valve, there is a "tee" handle. Take a hammer and a large punch and strike somewhat firmly on the end of it. Then take a pliers and tighten it clockwise like a nut on a bolt. If you can tighten it at all this may help with your leakdown issue. You might do this several times and if you beat on it so much you break something.....you hit it too hard. To expect zero leakdown doesn't usually happen. Most have some internal valve leakage. Fix your external leak and you can use what was provided to keep things raised up.
Edited by DrAllis - 06 Mar 2022 at 7:24pm |
