late 7000 vs 7020 differences |
slimbo3006 ![]() Bronze Level ![]() ![]() Joined: 20 Apr 2024 Location: Virginia Points: 16 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Jun 2024 at 7:56pm |
OK I am looking at two different tractors. One is a 7000 Black Belly (1979 I believe) and the other is a 7020 (1978 possibly 79) both tractors are similar, they have cab and rubber is about the same on both. They both need a little TLC but are repairable and thus priced likewise. What are the main differences between the 2? any one significantly better that the other? They both have the same 649T engine only the 7020 has an intercooler thus a little more HP correct?? What about transmissions? Do both tractors have a wet clutch? Not 100% sure yet but the 7020 has a power director transmission. based on the year I am guessing the 16 forward and 4 reverse...but not sure yet. I hear a lot of people say the powershift transmission is better.. Which brings the question....What exactly is the difference between a power Director and a Power Shift? How do they differ in operation? Any other major differences to be aware of between the two? rear gears? Hydraulics? all other things equal, at similar prices, is one significantly better than the other for any reason. Edited by slimbo3006 - 11 Jun 2024 at 8:05pm |
SilverShoes ![]() Bronze Level ![]() Joined: 20 Feb 2014 Location: Seneca, Kansas Points: 169 |
7000 in my mind is a glorified utility tractor. Open center hydraulics, small frame ect. 7020 has closed center hydraulics channel frame, power director or power shift. Both good trannys but for longevity I’d go with the power director. Just my thoughts
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3536 |
[/QUOTE] Which brings the question....What exactly is the difference between a power Director and a Power Shift? How do they differ in operation? [/QUOTE]
20 speed PD has; 5 gear trans x 2 shift Range (Slow/Fast) x 2 Foot floor buttons(Low/High). 16 speed PD has; 4 gear trans x 2 shift Range (Slow/Fast) x 2 foot floor buttons(Low/High). 12 speed PS has; 6 gear trans x 2 shift range (Slow/Fast). Both PD require foot clutch to be disengaged to shift both Trans & Range. Floor foot buttons are “on-the-go” shifting(no clutch). Floor buttons are usable in every gear/range, so extremely convenient for slower headland(turnrows) maneuvering. 16 speed was standard. 20 speed was optional. PS’s trans gears 1-6 can be shifted “on-the-go”(no clutch). 2 speed range shift requires foot clutch disengaged. Operators right hand can quickly move 6 gear trans lever between desired speeds. Heres a photo of each trans console. PD is on the left. PS is on the right. Both trans have a Range shift lever on their right sides (Park-Slow/Fast). PD's T-handle can twist&To-Fro for selecting 1,2,4 forward, 5,3,R rearward. PS's lever moves forward 1-3, then 4-6 & moves back for R. ![]() All the 7010,7020,7030,7040,7045,7050,7060,7080 models have Rear-end Differential Lock as standard equipment. Don't think the 7000 offered it?
Edited by AC7060IL - 12 Jun 2024 at 9:29am |
CAL(KS) ![]() Orange Level ![]() Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
isnt the 7000 basically a 190/200 with a 3 speed pd? or is that just the maroon belly?
Thank you AC7060IL!!!! that is exactly the info I was looking for on the transmissions. It seems online everyone uses Power Director and Power Shift interchangeably so I have never been 100% sure which was which. Seen where many people refer to the foot buttons as the power shift button.... As for the one I am looking at. He says it has a PD but I'm not sure which one. Waiting on pics. I am kinda leaning towards the 7020 right now. What is the advantage of the Closed Hydraulics? I see looking at specs that the 7020 is rated at double the gpm as the 7000. Other than the flow, what are the other differences? Just from looking at the pictures, I see the 7020 does not appear to have the hydraulic pump mounted to the engine in the same place as the 7000. |
Edited by AC7060IL - 12 Jun 2024 at 11:53pm |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
That was the maroon belly. The black belly 7000 was more similar to its bigger brothers.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21919 |
The black chassis 7000 got the new Acousta cab 2 like the bigger tractors did. The black chassis got the gear shift moved from the floor to the side console as a "TEE" handle shifter like the 7010's and up. The Power Shift clutch was changed slightly internally to use "low" range as the inching clutch, instead of the dry clutch on the flywheel. Other than that, it is the same tractor as the maroon chassis models. Nothing in the drive line is shared with 7010's and bigger. The bloodline came from the 190/200 and while the rear end housing and 3-point hitch look very much the same, I can assure you not one part in the transmission or final drives is the same as a 190/200. The differential and brakes are similar, but that is it. The torque tube is a completely different casting and different internals from a 190/200. A fully independent 540/1000 PTO was standard equipment on the 7000 tractor.
Edited by DrAllis - 13 Jun 2024 at 9:26pm |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3915 |
what one would be a step up from the wd45
D-17 replaced the WD-45.
just trying to be funney , but thier are lot big changes each year ,model after the 100 series.... i would not know any of the goods or bads
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5097 |
The difference between a 7000 and a 7010/20 is about like the difference between a WD45 and a D17 lmao! Entirely different drivetrain family.
bigal121892 ![]() Orange Level ![]() Joined: 05 Jan 2010 Location: Nebraska Points: 812 |
Given the choice, go with the 7020.
Yea After doing some research I am definitely leaning this way. Just dealing with some logistical issues with picking it up.
DON G ![]() Silver Level Access ![]() ![]() Joined: 14 Feb 2014 Location: Lowpoint, IL Points: 419 |
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2388 |
And massive wet clutch, differential lock, planetary final drives, much heavier 3 point, far better hydraulic system and bigger rear end components. Plus, more common parts with the other models.
GM Guy ![]() Orange Level ![]() Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
7010+ is a vastly superior tractor to a 7000. From a marketing perspective I think that Allis even making the 7000 hurt them. Hard to have one sitting on the lot and be claiming "all new improved design" and then have a lot cruiser walk around the "same ol (you know what) in a new dress" that was the 7000. yes, 3 speed, live PTO, etc. so it was improved from the 190/200, but I would have been alot happier with it if they just called it the 205 and made it a sister machine to the 185 and didnt let it wear the updated bodywork.
Updated body should have been exclusive to the updated drivetrain of the 7010+ So, in closing, buy the 7020 and pass on the 7000. if 7020 sells before you get to it, start looking for a 2-105 White. Id personally avoid the 7000.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
I have pretty much decided on the 7020. Have a couple off different ones I am looking at. Even found a 7045 at a good price too, but just don't need that much tractor. How does the PTO operation on the 7020 work? Is it "live" PTO where I can push in the clutch (partially) to stop the tractors movement and the PTO still spins? if it it different, while baling hay, how would you stop the tractor but keep spinning the baler to to allow it to tie the bale? it is a 4 sp Power Director if that makes a difference
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2572 |
Yes live… stop tractor with foot clutch and pto keeps a spinnin’
Blue Skies and Tail Winds
Dana |
Michagman ![]() Bronze Level ![]() Joined: 18 Jan 2023 Location: Michigan Points: 17 |
Let me start by stating I would probably choose a 7020 over a 7000. I just never understood all the bad comments about the 7000. Our big tractor was a 7000 for quite a few years and it was always up to the job.
I wouldn't have even posted, but you mentioned baling. Our 7000 is still my favorite tractor for round baling, in my opinion the 3 speed power shift is perfect for the task. I have baled with Power Director and true Power Shift tractors as well. We never had a 7020 so I am no expert on them. If we wanted to speculate about their potential problems though, how about their engines being turned up higher than in any of the other tractors with those engines? All of these tractors are over 40 years old, a 7020's hard life could have been worse than a 7000's hard life. |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5025 |
The biggest difference is the 7020 is about a ton heavier.
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8720 |
Slimbo, if you found a 7045 for the right price, I wouldn't rule it out. Probably wouldn't be quite as fuel efficient as a 7020, but for the most part, a tractor will consume fuel per the load it has on it/job it's doing. And you can always do small jobs with a big tractor, but you can't do big jobs with a small tractor. So if even once or twice a year, you need a little extra power, you'll have it.
Darrel |
