K 2 Traction drive and governor seal |
KY
Topic: K 2 Traction drive and governor sealPosted: 24 Sep 2016 at 9:37pm |
What are the adjustment specs for the idler for the traction drive belt on an early K2? It seems too lose when in slow position and too tight in fast position. Any tips for replacing the governor box seal? Thanks
KY
Posted: 26 Sep 2016 at 3:25pm |
Bump
Dans 7080
Posted: 26 Sep 2016 at 4:14pm |
Are both pullies moving? The belt shouldn't be real tight. If he spring one is froze up it will make the belt get a lot tighter.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
KY
Posted: 26 Sep 2016 at 10:14pm |
Yes both are moving. In slow position it slips and in high position it is super tight if you tighten the idler up enough to make it pull in slow position
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 27 Sep 2016 at 9:08am |
on my "K" the drive belt would slip if pulled all the way back.....but just bump the lever ahead and it would take off good. just a bump.
Dans 7080
Posted: 27 Sep 2016 at 9:10am |
It will tighten as speed is increased. I will check the manual and see if it says anything. I always just snugged it up in the slow position and never had any trouble.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8757 |
Posted: 27 Sep 2016 at 8:27pm |
Doesn't a K2 have the torque sensing spring can on the lower shieve? It needs greased daily if it does. 1/8 or 3/16 gap(don't remember) when together.With torque sensor belt will appear loose when stopped but tight when running.
KY
Posted: 28 Sep 2016 at 6:42am |
Yes it has the torque sensing bottom pulley but it is moving correctly. If I tighten the idler up any in slow position to make it pull the belt is do tight in fast I'm afraid it's going to destroy bearings or break
