Is this aftermarket or home brew?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Topic: Is this aftermarket or home brew?
    Posted: 02 Feb 2012 at 4:30pm
http://www.ebay.com/itm/Allis-Chalmers-WD-WD-45-Tractor-Lift-Arm-Hydraulic-Cylinder-Lift-Assist-/260947850862?pt=LH_DefaultDomain_0&hash=item3cc1b4366e#ht_500wt_1287
I don't see a reason for doing this.  My WD will bring the front off the ground long before it runs out of lift.
AaronSEIA
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 5:19pm
Looks very well made if nothing else.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 6:01pm
Hmm. Never seen one of those set ups. Anyone??  Ryan
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 6:10pm
Would it be for lifting a heavy mounted picker, if they are turned to face forward rather than attaching to the rockshaft at rear? It does seem like overkill, but somebody felt they had the need.
Edit-on closer inspection, I see my theory is all wet.
Edited by redline - 02 Feb 2012 at 6:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 6:18pm
How much torque is there on the bolt that holds them on in the front?  Seems like this would be the weak spot.  Wouldn't want to blow one side or the other while sitting in the seat!
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:03pm
First does anyone have a parts book that shows this as an accessory or is it home brewed?
Second, if you add two cylinders but T them to the same line as the originals how much more lift would they provide?
AGCO My Allis Gleaner Company
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:43pm
i would say chances are good that it is factory, I have a factory setup for adding lift cylinders like that to a D17. You will get twice the lift, but at half the speed.....
ALLIS EXPRESS!
This year:
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 8:02pm
I have a set like that I removed off a WD45, it looked factory to me. I parted the old girl out and have not used it. On the weak link at the cly end my unit has a bracket that went from the cyl to the lower finder bolt hole on both sides.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 7:39am
I never found anything that a WD45 wouldn't lift!
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 9:05am
Pretty sure it was an Allis Chalmers part. I have seen them on a few WD45's.
