intake manifold on 7060 |
Kevin210
Topic: intake manifold on 7060Posted: 24 Oct 2025 at 9:14pm |
So I'm putting an inner cooler off a 7060
on a 220 and it has some sort of an probe for lack of knowing what it's actual name is but I think it is the ether injector maybe,any help would greatly appreciated. This one is broke off. |
Posted: 25 Oct 2025 at 7:43am |
Ether atomizer. It's brass. Carefully drill it out I guess. How are you going to connect up the coolant flow on a 220 water pump?? or is this a newer Mark II engine from a 7000 series??
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2424 |
Posted: 25 Oct 2025 at 7:49am |
Yes,likely the ether injector. You could leave it, block it, or drill it out. It's made of brass so it would drill easily but getting the chips and pieces out of the manifold could be a chore unless you have the inner cooler disassembled.
Kevin210
Posted: 25 Oct 2025 at 9:48pm |
I haven't got to that bridge yet Dr Allis.
Yes I have the cooler out of the manifold. |
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4553 |
Posted: 6 hours 43 minutes ago at 6:46pm |
Been there done that. Have a 3500 MK II engine in my 220 that I added an intercooler. To get proper flow, you will require the big waterpump that only discharges to the left side. Now you will need to move the lower rad inlet from the right side to the left side. While I was at it, I recored the rad with 7 rows. to finish it off the alternator is now on the right hand side.
Calvin Schmidt
Posted: 6 hours 33 minutes ago at 6:56pm |
Lynn Marshall
Posted: 3 hours 15 minutes ago at 10:14pm |
Calvin, your 220XT evidently uses a cam driven oil pump. Was the original engine like that too?
