Install water pump on AC 7040 |
jazzsuds
Topic: Install water pump on AC 7040Posted: 08 May 2017 at 9:05pm |
Allis Chalmers 7040.Changing a water pump. I used a pulley and pulled the pulley off of shaft.All bolts are removed but I can't get the pump to come off? Any help will be appreciated |
MACK
Posted: 08 May 2017 at 10:08pm |
There is a ällen head bolt, did you find it? Another down low that is kinda hard to seen. MACK
jazzsuds
Posted: 09 May 2017 at 12:50am |
Thanks Mack. Yes I did find that when I pulled the pulley off but it still will not come off? Any other ideas?
Thanks
jazzsuds
Posted: 10 May 2017 at 8:38am |
Here is a picture of what is left on the water pump I'm trying to remove. Is it that round piece at the end of the shaft before the pump That is keeping the pump from coming off? If so how do I get it off? Thanks
![]() Edited by jazzsuds - 10 May 2017 at 8:40am |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 10 May 2017 at 10:51am |
Probably just glue holding it in place. Try a dead blow hammer.
Wink I am a Russian Bot |
jazzsuds
Posted: 10 May 2017 at 11:02am |
OK thanks I will try it
