Injector washers |
cdreb ![]() Bronze Level ![]() ![]() Joined: 27 Oct 2009 Location: SE-IA Points: 114 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Oct 2010 at 6:48am |
What is the best way to get the copper sealing washers out from the seat they sit in ? This is on a 3500, 7060 the 190's are easier, but these are bigger diameter and IT book says nothing. Thanks guys
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21485 |
They are exactly the SAME part number for 426 and 301 engines.
Adam Stratton ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
Someone told me to use a 5/8 coarse thread tap. Put a little down pressure on it and screw it in with your hand, and after you feel it bite, pull it out. I have only done it once, and it worked like a charm. Good luck!
skipwelte ![]() Orange Level ![]() Joined: 29 Oct 2009 Location: Anthon, Iowa Points: 723 |
Ive used and oring pick to get under the ring and pry it up. The 5/8 tap sounds like a good idea too. |
